I'd say 4, probably. But of course there's no way of knowing.
I'm joe.
I'm Gone.
For many years, I have cleaned the end caps and holders of all my system fuses with Brasso wadding or DuraGlit. I also clean the connectors of mains plugs and sockets the same way. For the last few years I have also treated them with DeOxit. I do this with the annual service, or if I make any changes to the system.
I'm scott.
fuse just could have better contact with the pcb mounted fuse clips
or apply contact cleaner or enchancer to the fuse & fuse clips , much cheaper than buying fancy mains Fuses
Walker SST myself every connection in my system is covered in it
How much does that stuff cost, Scott?
That's what I'm trying to determine... Scott's claiming that it's cheaper than buying audiophile fuses, so I'd like to see the evidence. I guess it depends on how many bog standard fuses you're upgrading or replacing.
https://walkeraudio.com/shop/e-sst-s...-for-contacts/
$185 in the us of a
Yoinks! A fuse thread....
One of these days... I'm going to cut you into little pieces.
Fook me 185 usd, duraglit it is then
I'm gone.
Walker SST - blimey that takes me back to my crazed youth!
-- I recall those sponge prongs with affection.
I had a jar of that decades ago - probably about 25-30 years or more I suppose it got a good mention in a mag - I read lots of them back then.
I recall it as horrible stuff to use, sticky/slimey and gets everywhere if you aren't careful (but then, I am a clumsy oaf) and is a bit of a booger to get residue off kit.
But mayhap they have improved the formula over the decades.
Sonically? - umm, not much to report! -- but my system wasn't very high rez back then, I guess.
I stopped using it, then went back to it after a year or 3, and it had solidified in the jar.
