How long do the screws need to be? I may have some that would fit.
I've just found my stash of cartridge screws. I've located something suitable and can send you a couple of long nylon M2.5 bolts that you can cut to length with a craft knife if you like. The advantage with these is that they won't mark the headshell or strip the threads in the holes. They're plenty strong enough for cartridge mounting. I use them myself. Let me know if you're interested.
Hi Geoff thanks bud much appreciated I will pm you my details and thanks to everyone for there attention in this matter. This is what makes the aos such a great forum cheers guys
Sorry Pete, I've been away a few nights and hadn't seen this thread.
I use a 440mla with the mg10 and have some screws of various lengths you can try mate.
Just giz a shout or pop over with it and we'll have a look.
R
One of these days... I'm going to cut you into little pieces.
Hi Rich cheers for the offer but Geoffs helping me out and very kindly sending me some screws which seem perfect for what I need btw how's your new system sounding I will pm you later today. Pete
No worries Pete, as long as you're sorted.
Aye the new system is running in nicely, putting some TQ Blue cable in has really brought it all together.
My vinyl set up is now good but I'm waiting for some more shelves to get it permanently in situ. So for now I'm just living with my various digital sources but its all good. Pop by and have a listen sometime.
Peter. I've also included an OEM set of alloy screws of various lengths, so you should be sorted.
