Originally Posted by
Lynster
I suspect just relocating your original internal supply to outside the TT will be just as effective and far, far cheaper. Check the forum for comments on this.
+1. By far the best VFM upgrade you can offer your deck. An after market PSU will do too, but it's a bit more pricy. It depends if you are handy with soldering a few components together.
Feet and Rewire will offer some subtle improvement, but won't propel the deck to any stratospheric heights sound wise.
Then I would offer the deck one of Mike New's bearing. You would have a serious contender by then.
IMHO...
Francois, Bergerac, France
Source component/s:
Musical Fidelity M1 Dac, Allo Digi One, Sony SCD-XE800, AVID Ingenium Twin arm, Audio Note Arm One, Groovemaster II 12in, Audio Note IQ3 MM, Denon DL103R MC, Croft Basic 25, TQ Iridium Phonostage, Puresound T10 Stepup Transformer, Zavfino majestic tonearm cable
Amplification:
Audio Note OTO PP, Dussun V6i
Loudspeakers:
Triangle Comete ES, Klispch RP600M
Cables/stands:
Quadraspire, Belden 9497
