TV LG55B7 OLED
Rega arms don't usually suffer from sticky bearings, so another mark down to the tonearm bodgers who think they can do better in engineering terms than Rega can. Sonics are personal, but how can adding a massive tube resonance or two right in the midrange make it 'better?'
My personal advice would be to get the arm fixed, if indeed it has sticky bearings (balance out the arm so the stylus is clear of the mat, take the arm to the centre and see how free it is in returning to the rest) and replace it with a pukka Rega arm, or possibly better for the LP12, a Michell Techno-Arm, which is 'bodging' done right and apparently then assembled and tested at Rega by people well used to building these things!
Try to look at the underside of the armtube if it touches the armlift during it's travel across the record.
So what have you got against Origin Live, they have a good reputation both in the trade and the public. I'm on my second OL arm and had/have no issues with either. Mark at OL seems to know his onions on the number of conversations I've had with him and I'm thinking of upgradeing my Encounter to the latest 'C' spec. Rega arms, like Technics seem to respond very well to fettling as many users on this forum can attest.
TV LG55B7 OLED
Look at reviews, speak to reviewers who know what goes on and also look at the finish! Like I said, change to a Techno Arm or something 'better' that will sadly cost rather more!
Like I said, making a pretty inert arm sing along madly with the music isn't 'High Fidelity' in my book. Sorry!
I'm Andy.
Blimey yes! That's the very first thing I'll do! I'm embarrassed that I didn't think of that. I'm working away from home today, which is infuriating as I'd have a 600 mile round trip this evening to do it. It will need to wait until tomorrow evening.
I actually remember on my old Rega RB300, there was a rubber strip in the armlift and it was a tiny bit too long so it stuck up a little at the 'inside' end. In that case, it actually lifted the arm slightly clear of the groove but, if the problem was just a little less bad it could maybe be the cause. Part of me hopes this is the issue (as it's an easy fix) and part of me doesn't (as I'll look like a prawn!).
So, the new plan for this weekend is:
1 - Check the armrest isn't interfering with the tube
2 - Check the tracking weight
3 - Check the alignment
4 - Check the arm returns nicely/freely to the rest from a floating position midway across the radius of the platter
5 - If nothing else works, send arm to OL
I'm afraid that I'm not qualified to comment on the relative merits of Rega, Michell and OL though I've had 3 Rega arms in the past and they've always been great. I do however think that the OL is more nicely finished from an aesthetic POV. I should add that I was originally planning to get an Audiomods upgrade done on my RB300 when Clive's OL Sliver Mk2 came up and seemed like an attractive and rather simpler alternative!
thanks
The arm floating test with no anti skate will show a sticky bearing or a trapped wire in the arm, don't forget to put your stylus guard on
also with the arm floating drop a 1cm square of paper on the head shell and the arm should pivot up and down freely as well
Do a full check on alignment and tracking on a test disc at the inner, centre and outer grooves.
Do a thouroug clean of he tip and look at it with a good pocket mic could be a build of crud on one side of he stylus
Alan
I'm Adam.
I would have fully supported these comments 15 years ago during the 'RB250 downgrade era' but today they are simply not relevant.
I trust no reviews but my own and now myself and several of my colleagues all run OL arms as a preference to many more popular offerings.
I make no secret of the fact that OL are a horrendous company to deal with and my recent experience has been without doubt the most unpleasant experience of my hifi buying and selling life, but when it comes to the products, they really are incredible.
Alas, I don't think OL will ever repair their bad reputation without a serious attitude adjustment.
