I follow you, Andrei! The 1210 has fantastic tight bass after the upgrades. My biggest upgrade in sound would be the Isokinetic tonearm and MN Bearing. I read a test of a respected reviewer in Norway, that not long ago reviewed the Nottingham Hyperspace. He wrote of fantastic built quality, dynamic open sound with very tight bass. The sound was dynamic and open on all sorts of music.
Then again, it costs alot of money. I know I would not go the upgrade route buying the cheaper Ace Spacedeck and then upgrading it to the level of a Hyperspace. If I buy a Nottingham it would be the Hyperspace. But I also love the sound of my 1210M5 with all the upgrades. Of course, the Hyperspace looks absolutely fantastic, but in the long run it's the sound that is the most important.
The ETP Platter with the base plate is not cheap either, but I love the way it changes the look of the Technics. As many of you know, I use a London Decca Super Gold. And even with Oyaide MJ-12 + Br-one, the platter is not silent. The Decca picks up everything and Hyperspace is well knoen for dead quiet backgrounds. Will 1210 with ETP/ baseplate be dead quiet too??
Is the ETP/ baseplate a big improvement or do owners use big words on small improvements? If you guys know what I mean.
Turntable 1: Technics SL1210M5G/ KAB PSU/ KAB Fluid Damper
Turntable 2: Rega P3 (new) Tangospinner & dual belt/ Rega Neo
Amplifier: Rega Elex-R
RIAA: Rega Fono mk3 & Schiit Mani
Speaker: Klipsch RP280f
Cartridge: Rega Exact & Nagaoka MP-110
Yes it does. No problem with drive and dynamics with a Nottingham Analogue.
BTW. You can't upgrade an Ace Spacedeck to a Hyperspace as there are differences to the motor mount and, crucially, the bearing, which is entirely different.
I'm Anthony.
The direct (and rim or idler) drives obviate the need for big heavy platters and slow start up times and are speed stable due to quartz lock.
Sure they sound different but its a matter of whether the sound characteristics of the combination of turntable, tonearm, cable, cartridge match your preferences. Different turntable configurations will sound different and direct side to side comparisons need to utilise the the same tonearm, cable, cartridge on the two different turntables to ascertain if one turntable is 'better' than the other..... otherwise, everything else like others reviews are just subjective conjecture and hearsay- everyone perceives sound/ music reproduction differently - so you can only make meaningful judgements on what you hear, yourself. Direct comparisons with the different turntable drive units/ plinths with the the same tonearm, cable, cartridge combinations to compare the side to side differences are the ideal but are difficult, if not impossible, to organise and undertake. So my advice is to choose the turntable combination that suits you best - irrespective of what other people say, the way it looks etc. Cost is the main consideration you need to make other than what sound characteristics to value most or want to achieve. Other things like serviceability, spare parts, upgrade path are further considerations.
I'm Anthony.
oops forgot to add quartz lock applies mainly to direct drives.....
Hugo, with respect, have you ever directly compared the two? the sheer mass of the Hyperspace platter totally negates the need for a high torque motor (this is what the Linn Lingo does too, just enough power to keep the platter spinning and no surplus which could cause vibration). The 'reason' why a high mass platter and high-drag bearing is often used on tweaked techies, apart from the butch look, may well be to smooth the over-eager Technics servo's for all I know.
The Hyperspace rocks too, really well if the arm and cartridge fitted allow it, but yes, it doesn't sonically jump in with both lead feet as a techie can. A heavily tweaked techie may not do this, but these are better compared to what exactly?
Sorry, I don't mean to thread crap here, but the OP really needs to directly compare the two as the stock techie doesn't offer much competition (told to me by an experienced trade poster here who's done the comparison with a medium-tweaked 1210 and who's ears I trust). A tricked out Techie may well be different though...
I'm Andrei.
Of course big words are used. The thing is though that most of us are intimately familiar with our gear, we know exactly what it sounds like. So when we make a change for the better we hear it straight away and it seems to be a big change. I was a bit surprised at myself just recently when I heard an improvement in sound from just a headshell (Yamomoto Sound made from African Hardwood).
To be specific: An aftermarket platter will I am sure be an improvement. When I did my platter upgrade (http://theartofsound.net/forum/showt...62-DIY-Platter ) it really did tighten up the sound. I cannot say specifically about the ETP platter as I have not heard it. However it should be better if only because the Technics platter is poorly damped. On the other hand I think you have the best mat (for the Technics) out there and I understand it is made in part from butyl which is what I have put underneath my platter - so the improvement may be small.
[COLOR=#a52a2a][B]Sources:[/B] [B]1[/B][/COLOR] PC & Wyred4Sound DAC-2 DSDse [COLOR=#a52a2a][B]2[/B][/COLOR] Oppo BDP105 [COLOR=#a52a2a][B]3[/B][/COLOR] Technics SL·1210 MK5 (Jelco 750D · Benz Wood). [COLOR=#a52a2a][B]Speaker Cable[/B][/COLOR] [COLOR=black]Nordost Frey.[/COLOR] [COLOR=#a52a2a][B]Interconnects [/B][/COLOR][COLOR=#000000]Oyaide[/COLOR][COLOR=black] & [/COLOR][COLOR=#000000]Geisha [/COLOR][COLOR=black]Silver.
[/COLOR][B][COLOR=#a52a2a]Phono Stage [/COLOR][/B][COLOR=black]Fosgate Signature V2. [/COLOR] [COLOR=#a52a2a][B]Preamp [/B][/COLOR][COLOR=#000000]Ayon Eris[/COLOR][COLOR=black]. [/COLOR] [COLOR=#a52a2a][B]Power Amp[/B][/COLOR] [COLOR=Black]ATC P1. [/COLOR] [COLOR=#a52a2a][B]Speakers[/B][/COLOR] Triangle Magellan Cello. [COLOR=#A9A9A9]Oh Sting, where is thy death?[/COLOR]
Yes I have, more or less, in that I had a modded Technics at the same time as a Spacedeck with Heavy Platter and Wave Mechanic PSU. Not quite a Hyperspace but not that far off in terms of platter mass; and identical in terms of motor and PSU (IIRC it's only when you get to the Dais that a more elaborate PSU is used, with the same motor).
I do agree that the OP needs to hear both, since they are very different beasts.
Thanks for clarifying. I never had a wow issue, but then, I came to them via an LP12
