I'm John.
Tannoyista.com - Audio Equipment Reviews
I don't think the knosti cleaner is at fault but the original chemical that came with it. Even after cleaning with brand new fluid it was impossible to play even one song without the stylus getting completely covered in crud but with the cheap and cheerful solution I have mentioned they really are super clean, even cleaning some really filthy s/h Lp's. I can tell no difference to this method compared to using a Moth RCM MkII that a good friend of mine has.
Just make sure you leave them to dry properly and only use 4-5 drops of rinse aid, a little goes a long way. I believe that the rinse aid (wetting agent) helps the water gets into the bottom of the grooves as it make the water thinner.
I once heard if you put wetting agent in water and then pour it into an upside down umbrella the water will actually go through the umbrella material.
rinse aid breaks surface tension
A good pre clean with an enzyme mix is often a good idea as well.
Hunter S Thompson
