Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Bayadera platter for Kuzma decks
    I'm gordan.
    Default Bayadera platter for Kuzma decks
    Something nice for Stabi S and older Stabi decks: an aftermarket sandwich platter by a local specialist.
    I have one for more than a year and it strongly improves detail and dynamics. However one has to be careful because the deck needs a good re-tuning and a precise VTA re-bias (if you don't take care, you may end with bright and dry result).
    It's enough to use a normal felt mat, no need for anything exotic.
    Gordan.
    Speakers: Oris Swing MkII
    Amps: Thomas Mayer 300b/ Hiraga La Maison de L'Audiophile 20
    Preamp: Silver AVC by eng. Ferenc Lazar
    Phono Preamp: Shishido LCR by Solaja Audio
    Decks: Garrard 301 Martin Bastin reworked/plinthed with Fidelity Research FR64fx
    Garrard 401 in eng Ferenc Lazar solid wenge plinth with SME 3012/2
    Cartridges: SPU Spirit/ Koetsu Black revisited by eng. Salai/ Miyajima Shilabe
    Step Up Transformers: Tango MCT 999/ Ortofon T-5000/ Lumiere SUT
    Digital: Shigaclone by eng. Ferenc Lazar with Lampizator Amber II
    Wires: of sufficient length
    Oooh… That is *just* stunning!
    I think Simon from Sheffield might take a look at this.
    PRE
    I'm Andy.
    x17
    Me so horny- Impulse H6 Horny
    Drats… I’d put you down for an 18.
    I'm Andy.
    Do not bring my waist size in to it matey.
    Don’t you mean your dress size? Are you quite ‘busty’?
    I'm gordan.
    No one's spotting my stylus guard?
    Gordan.
    I'm Andr'e.
    i did don't worry
    I'm Doruk.
    Hi Anubisgrau
    Didnt want to open up a new discussion, can ı just ask your opinions about your Kuzma deck?
    I am interested in buying one and wondered if you are happy with it? How can you describe its characteric? Have you had any chance to compare it other TTs?
    Many thanks.
