Pre & Power
QED SDR Passive
Technics SE A909S
Turntable
CD Transport & DAC & PSU
Loudspeakers
Tannoy 615 MK2
Speaker Cable , Digital Coax , Interconnects
QED Speaker Cable , Chord Coax Digital , Groneberg Quattro Reference Interconnect , Belkin Interconnect
If all the electrolytic capacitors are OK then this should be fine. If the electrolytic layer in any of them has re-dissolved (as it tends to) and doesn't re-form quickly enough then shortly after switch-on there will be one or more very loud bangs and clouds of smoke and the inside of your amp will be filled with what was previously the inside of the capacitor(s). Scraping the goo and removing the foil fragments off the circuitry can keep you busy for ages.
VB
AmpRegen Ltd - Vintage Valve Amplifiers http://www.ampregen.com
I'm Andr'e.
Not the end of the world cos the '30 Plus' has slot in cards like the Quad '33' dead easy to service..If you want the service manual Dan the man i can mail it you..
Nothing through the headphones using cheap cables as big cables are too large for the diameter of the inputs using tuner with a pioneer tuner nothing tried all inputs. Not gonna put speakers through it neither worth sending of to a specialist i want to but no power output its likely to be a big bill but would be a nice little thing if i can get it running.
Pre & Power
QED SDR Passive
Technics SE A909S
Turntable
Loudspeakers
Tannoy 615 MK2
I'm Andr'e.
Have you checked the DC fuses Dan?
That's reminded me of a very amusing memory of my time in a TV repair shop in my teens.
The proprietor was facing the open chassis of a TV on test (all valves of course then) when the main electrolytic 'let go'.
I was at an opposite bench, turned around to see his lab coat, face and hair plastered in aluminium foil, apart from the insides of the TV
Alan
Pre & Power
QED SDR Passive
Technics SE A909S
Turntable
Loudspeakers
Tannoy 615 MK2
I'm Andr'e.
On the back in fuse Holders
There is provisions for spare 5x20 glass fuses on the back aswell {1.6A D.C & 1A A.C} If the D.C fuses blows you might be looking at an output Transistor failure..
This amp uses a Quasi comp output {2N3055 NPN's} If you have to replace the Outputs of Driver Transistors for this amp the quiescent Current wants re-setting at 30mA.
Id personally get all those Elco's replaced for starters..
Hi
Yes the 1.6A replacement fuse is fine..The leak powered up fine playing a CD through it and through the headphones it sounds OK no distortion the sound is good. Ive run it for about 20 mins i will send it off for a service. though i'm through the first process it powers up and it plays fine well to me for the moment anyway. Lovely little thing it is. .
Amplifier electronics is still a mystery to me although learning the basics through this very forum so all is good.
Thanks
Pre & Power
QED SDR Passive
Technics SE A909S
Turntable
Loudspeakers
Tannoy 615 MK2
I'm Alex.
