Hi All,
In the midst of trying to sort a seperate annoying distortion problem (being discussed in another thread), i'm looking at possibly having to try swapping my stock techie arm for another stock techie arm i have in stock to try and isolate the problem to the arm (having ruled out everything else).
But, at the same time, the opportunity obviously then arises to re-wire the original stock tone-arm, whilst it's out of the deck. (seems sensible and something i'd been thinking about doing anyway tbh)
Now, I can't afford a new/replacement arm (I wish i could but..) having just splashed out on a new Firebottle MM+ from Alan (brilliant investment btw!) but can just about justify a re-wire kit for the stock arm (so budget around £100)
As far as i can see it there are two that fall into that category.
1. - http://www.mains-cables-r-us.co.uk/v...l12001210.html
(from MCRU)
2. KAB rewire kit made up by KAB on request - https://www.kabusa.com/frameset.htm?/
Any other options i'm missing or any thoughts on experience with any of the above?
The idea of one uninterrupted continuous length of cable from mounting collar to RCA plugs does appeal (so theory of the less connections to get in the way the better)
Any one better than the other? (he says lighting the blue touchpaper of debate...)
As ever, thanks in advance for people's thoughtful input.
Chris.
