Aye, it sounds pretty good, shame he's only got 5m left, I could have rewired the OB's internally.
Hunter S Thompson
Give single strand installation cable a try! Preferably with a similar twist to ones you show pictured. That, will give you an eye opener
And as an extra tweak, try one twisted pair per conductor. (In total two twisted pairs per speaker connection)
Plenty of decent wire here
http://stores.ebay.co.uk/Hollow-Stat...=p4634.c0.m322
Alan
As it turned out I didn't like this cable as it high lighted some distortion I was hearing in the upper mids. It works very well for bass and lower mids so in another set up it might shine.
I took it out and replaced it with plain 2.5mm OFC I stripped out of some old Van Damme tour grade cable that I had lying around. This was much better at concealing some of the distortion.
I've never been completely happy with the passive cross over, either before or after the re-cap. I hear distortion around the mid to tweeter x-over point. I've heard it on other examples of the NS-1000M, I had it on my Celestion 66's and hear it to some degree on almost every passive three way I have come across. It's mostly noticeable on voices, especially Female. I decided to try a simple analogue active filter circuit in an attempt to get rid of this problem, I'm using the ready made modules by KMTech. The passive is a simple circuit without any notch filters or zobel networks so a simple analogue filter using Op-Amps might work without the need for any frequency equalisation etc. The PDF file linked here: http://www.jkwynn.co.uk/Project_Imag...ver_Layout.pdf
shows the layout I drew up, it has a power supply, also by KMTech, you just need to add a Transformer. The 30VA I used is overkill and one of 15 to 20VA would have done the job if I could have found one. I've tried to keep the AC path well away from everything else and to avoid the DC tracks crossing the signals, which I have kept as short as is practical. I am building high quality volume pots into the outputs to allow channel matching for amplifiers of different power ratings and sensitivity. The standard PCB mounted RCA sockets will be removed from the boards, I just used library pictures of the products for the layout.
It all fits into a 17" x 1U case which is 250mm deep, this is only marginally bigger than my Croft pre amplifier so it will sit under this on the shelf. I bought a ready made case and started work fitting the power supply.
This is the back panel and a trial fit of the fused IEC socket, the RCA sockets and the label I made to help identify the inputs/outputs. I went for a traffic light system, Red for Tweeters normaly at the top, Amber for Mids and Green for Bass normaly at the bottom. These all have Left and Right channel variants which are indicated by Red and White RCA sockets/plugs as normal. I will colour code the leads and amp channel inputs, also the speaker outputs to make it all fairly idiot proof. I don't want to accidentally plug a channel with power and frequency tailored for a bass driver into a tweeter, not if I can help it, so the clearer the better.
I fired up the power supply to test the "Power On" LED. I put a standard LED across the whole of the dual voltage output (-9.8/0/+9.8) so about 19.5 volts dc. This will allow it to discharge both pairs of capacitors in the PSU when switching off. This calculates to approx 750R for the anode resistor, but with the 20 mcd LED used I thought this was too bright, and I don't like really bright lights on my gear. As can be seen in the centre of the picture I used a very small pot on the LED and turned it down till it was the brightness I wanted. I then measured the pot resistance (1k2) and soldered a resistor of that value on the long leg.
The crossover modules arrived from KMTech. The Yammies cross at 500 and 6000 Hz, these boards cross at 501 and 6090 Hz which is the closest match using standard resistor/cap values. I'm not using the stock PCB mounted RCA sockets, so I've added extension wires to the boards made from wires I stripped out of some Klotz MC-5000. The input cables are made from the same, but I just stripped off the outer jacket and copper shield on these. As I will probably be using interconnects made from Klotz MC-5000 it made sense to use this on the internal connections.
Got all the wiring done, crossover boards now have power to them and I have wired a couple of cheap 10k dual gang volume pots into the output to control mid and tweeter levels. I didn't see the point in splashing out on expensive pots till I have an idea of how good the crossover is. Must say I am a bit concerned about all those wires and the possibility of crosstalk.
I managed to do a basic check that things are working. I played each pair of outputs in turn through a stereo amp and a pair of passive speakers. This confirmed HF/Mid/LF output from the boards and that the level pots were wired up correctly.
I now have to construct some new rear panels for my Yamaha speakers with three sets of speaker connectors, I want to keep the existing panels with the passive crossovers attached un-altered, in case I ever want to revert to original spec.
Made the rear panels for the speakers, the camera has made them look crooked and a bit scruffy but they are square and straight in the flesh and look much smarter.
I made suitable laminated labels for the panels and mounted the connecting sockets.
I only ever use "Z" type 4mm Banana plugs, so I'm not a fan of bulky multi function binding posts. The panel sockets I used (inset) stand only 5mm off the surface and are high quality items from "Hirschmann" they are solid Brass, Gold plated and rated at 32Amp. RS do them at £2.04 each with free delivery.
