Page 13 of 28 FirstFirst ... 3111213141523 ... LastLast
Results 121 to 130 of 280
Thread: Yamaha NS1000M - Tweaks
  1. #121
    I'm shahrin.
    Hi guys u see from my gear that i use some old sansui integrateds
    95 % of the time i have the au111 'flat' with tone defeat ON v occasionally on quiet listening i may turn on 'Prescence ' which bňosts bass a bit
    Very occasionally i might use filters to compensate fir crappy vinyl cd etc
    Not a purist
    I like that flexibility
    If i were to go active w the ns1000 using the minidsp mentioned can i 'fiddle ' ?
    Could i set presets for a bit of bass boost etc
    Thanks for indulging me exploring this which is entirely new to me
    Thorens td124 mk2 / Bokrand AB309/ 103r
    SLAT L75 / Jelco 850S / AT VM740ML
    Marantz CD63 / Bluesound / Musical Paradise 701 II/ ESP 500Hz eXO / PL Prologue 4 and Nord 1UP amps / JK Wynn semiactive NS1000 upgrade
    /ESP 700 Hz eXO / JBL 4333 components
  2. #122
    I'm Simon.
    I had a pair of Ncores here for a while. They sound great on the bass, but bring a somewhat steely edge to the mids and treble that sounds a touch synthetic. Not the best match with the Ns1000m
  3. #123
    I'm inthescottishmafia.
    Quote Originally Posted by drSM View Post
    Not a purist
    Have my eye on one of these for my new Open Baffle project, this should have all the flexibility you want-
    https://www.minidsp.com/products/min...inidsp-4x10-hd
    Hunter S Thompson
  4. #124
    In any case, if you are running actively nd want a little more bass, just turn up the amp driving the woofers a little.
    Hunter S Thompson
  5. #125
    how many drivers in the ob ali??
    I'm shahrin.
    Thats good news Thank you
    This project to 'activate' the ole yammies could b fun
  7. #127
    Two Eminence Alpha 15", a Crystal D500 midrange horn and an Isophon DKT tweeter per side Grant. I was also looking at that unit as it gives me the option to go balanced.
    Hunter S Thompson
  8. #128
    I'm Ken.
    I had a pair of Ncores here for a while. Not the best match with the Ns1000m
    Interesting Simon, I would suspect from this that you are running your Yammies with the stock passive crossover.
    One of the things I have found with my active set up is it has a warmer richer mid section and highs compared to the original.
    If what you say is a trait of all the Hypex variants it might balance itself out, we will have to see, but thanks for the heads up.
  9. #129
    I'm Mika.
    Based on my experiences the hypex UcD (class D) modules and many similar ones are good for bass only as with the Be-drivers for the mids and treble the modules bit clinical and harsh sound become too obvious. Personally couldn't handle that sonic signature at all..
    Loricraft / Garrard / SME / Transfiguration / Dynavector / Ensemble / Auditorium 23 / Shindo / RA / Audio Note / Duelund / Altec
  10. #130
    I'm Ken.
    Mika - What was your set up using UcD, was it 180/400/700 and which variant ST or HG, did you use the HxR regulators also?
    Getting a bit concerned now.
