Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Help - Local ears needed (North East)
    I'm Rich.
    Digi cable?
    Same issue with toslink and coax Ali.
    One of these days... I'm going to cut you into little pieces.
    I'm Nick.
    I have seen DAC chips them self fail a couple of times. Normal troubleshooting is getting them to play a sine of triangle wave and look at the output with a scope and FFT. Doesnt help you, but just to say it can happen.
    Nick.
    I'm Rich.
    Quote Originally Posted by lurcher View Post
    Thats interesting Nick. Any ideas on what might cause them to fail and would this normally manifest itself in a muddled and tizzy sound.
    Hi Rich,
    Sorry I run out of time before we solved it completely but SWIMBO called we have three of the grand children staying tonight so she called for back up
    Anyway back to the problem, there is something wrong with your DAC or interconnecting lead or digital source ?
    Unplug all the leads from the Dac and switch off unplug for 10mins
    Switch in and only plug in one reliable source suggest your SBT and the same analogue cable we used that sounded good to the amp
    If that sounds the same as the SBT or good without distortion then the DAC is OK and you have a dodgy lead or source ?, maybe its your TV or the CD player
    In any case looks like your speakers and amp are OK
    You could also bring your DAC to my house and try it there, if its knackered you could send it back to rega
    I have at least 4 dacs at home so your welcome to borrow one for now
    Alan
    I'm Nick.
    Quote Originally Posted by RichB View Post
    Its probably not the same, the ones I have seen fail are all ladder dac's and I think one or more switches go, so you loose one or more bits of resolution.
    Nick.
    I'm Rich.
    In one simple move the problem seems to have disappeared...
    Replaced the bridging connectors on the speakers with some better quality links made out of a bit of gale cable I have lying around.
    Its not muddling up the music any more. Those pressed metal connectors really are awful. I should have pulled them out to start with.
    must have bee a poor connection. i dont much like them either but seem to be common now.
    Good to hear Rich, Glad you have it sorted
    I hate those plate links they are a cheap piece of brass normally gold plated, much better to make up some dedicated wire links or Bi Wire
    Alan
