Page 1 of 6 123 ... LastLast
Results 1 to 10 of 60
Thread: Additional Headshell Mass with a 103R in a Standard SL1210 Arm?
    I'm breathing.
    Default Additional Headshell Mass with a 103R in a Standard SL1210 Arm?
    Hello,
    I've got a Technics SL1210 Mk2 here in totally bog standard form, its in lovely condition thankfully. Does anyone here use a Denon 103R in a totally standard un-fettled SL1200 here? If yes, did you need any additional mass (and how much approx) added to the arm or head-shell as its a fairly low compliance cartridge in a medium mass arm (I believe).
    I've got a DL110 too which I think is a straight drop-in with no additional mass needed, just toying with either going in.
    Thought's?
    Ta's!
    DTB
    Hi Dave,
    How’s it going? Still building some nice DIY kit? Nice to see you popping in from audio talk
    We’ve actually been discussing that very subject recently on a couple of threads. See this one (and my responses from post #10 onwards: http://theartofsound.net/forum/showt...oil-cartridges and also this one from the beginning: http://theartofsound.net/forum/showt...-DL103-or-103R
    If you’ve got any other queries, just give us a shout!
    I'm Hugo.
    Thin lead sheet strip, usually sold as 'dolls' house lead flashing' is useful for adding mass - it can be simply wrapped around the end of the arm tube and it's easy to find the optimum extra mass. Here's an example: http://www.ebay.co.uk/itm/Real-Thin-...item2c94d61bb8
    I'm breathing.
    Hi ya Marco, yeah, I only know how to build nice stuff, ugly ones are a no-no! Arf!
    Ta for the links, I had a quick search through a while back but hadn't seen those threads. I'll have a read through at Lunchtime.
    ... and it's easy to find the optimum extra mass.
    Thanks Mr A Acoustics, I've got some thin lead sheeting, thats 'andy 'arry! Y'say its easy to find optimum extra mass, I'm all ears tell me more please.
    I'm Andr'e.
    Ive got a bag of these 3g Techy headshell plates. I fit extra long cartridge bolts so that the heads are under the cart, the extra long bolts sticking upwards, i just stack on top then till im happy.
    You can temporarily make a Low Mass arm Higher Mass but you can't make an high mass arm lower
    Check if they’re magnetic, dude, ‘cos some are, and if so, next to useless…. The last thing you want is a big magnetic lump next to yer cart!
    I'm Andr'e.
    I don't use em i do massy experiments with em
    Ah, gotcha
    I'm breathing.
    FWIW the Technics Headplate I got from Juno is magnetic.
    I'm making up a small brass plate to add mass.
    More news as it's made, whahey!
    DTB
    I'm Andrei.
    Quote Originally Posted by The Barbarian View Post
    Well of course you can. Just follow the surgeon's motto: 'When in doubt - cut it out'.
    [COLOR=#a52a2a][B]Sources:[/B] [B]1[/B][/COLOR] PC & Wyred4Sound DAC-2 DSDse   [COLOR=#a52a2a][B]2[/B][/COLOR] Oppo BDP105   [COLOR=#a52a2a][B]3[/B][/COLOR] Technics SL·1210 MK5 (Jelco 750D · Benz Wood).    [COLOR=#a52a2a][B]Speaker Cable[/B][/COLOR] [COLOR=black]Nordost Frey.[/COLOR]    [COLOR=#a52a2a][B]Interconnects [/B][/COLOR][COLOR=#000000]Oyaide[/COLOR][COLOR=black] & [/COLOR][COLOR=#000000]Geisha [/COLOR][COLOR=black]Silver.
    [/COLOR][B][COLOR=#a52a2a]Phono Stage [/COLOR][/B][COLOR=black]Fosgate Signature V2. [/COLOR]   [COLOR=#a52a2a][B]Preamp [/B][/COLOR][COLOR=#000000]Ayon Eris[/COLOR][COLOR=black]. [/COLOR]   [COLOR=#a52a2a][B]Power Amp[/B][/COLOR] [COLOR=Black]ATC P1. [/COLOR]  ​ [COLOR=#a52a2a][B]Speakers[/B][/COLOR] Triangle Magellan Cello.     [COLOR=#A9A9A9]Oh Sting, where is thy death?[/COLOR]
