I'm looking for a cable: ipod dock connection end of cable -to- stereo connections on amp. Bought one recently hellishly expensive but have lost source. Ideally; looking for one sensibly priced.
Any suggestions appreciated.
This sort of thing?
http://cgi.ebay.co.uk/Retractable-St...d=p3286.c0.m14
Shian7
Kudakutemo
kudakutemo
ari mizu-no tsuki
Though it be be broken -
the moon on the water.
- Choshu.
http://www.flashbacksales.co.uk/acat...ck-cables.html
Something a bit more "audiophile"
Naim ND5 XS, nDAC, XP5 XS, 202, HC, NAPSC, 250.2, B&W 804s.
AVR350, B&W HTM4, Gallo.
Samsung, Oppo.
I bought a Cambridge audio ipod dock from richers for £10 a while back, it had standard RCA's on it.
They swim... the mark of Satan is upon them. They must hang.
FLAC / WDTV Live / Cambridge Audio / Tannoy VX12
DaveK.
My System:
Mike. Yep, that sort of thing but longer and better quality. Trailer, yes but with RCAs on the other end. Steve who / where is 'richers' ? I have been told that these have to be made to order. Surprising. I have trawled the web to find the item. Assumed it would be common.
Dave C The cable I recently bought from one of the better known providers on the scene cost over £60 for a metre long as, I was told, they have to be made to order but cannot remember who it was, not that I'd want to go back there.
Must be a source somewhere.
Obviously I went down the page. Still cannot see one. Give us another clue then ? I need a RCA pair at 'tother end. Cheers
See my edit
Just a quick word an iPod cable may not work with an iPod/iTouch as the pin outs are different. If you want to use it on an iPod/iTouch check with the vendor first that it is compatible.
The other option is to use something like this
http://www.ibasso.com/en/products/show.asp?ID=38
and supply your own cable.
Samsung, Oppo.
