Specifications:
2 way high fidelity bass reflex stand mount.
Frequency response (measured): 30Hz-20KHz
Sensitivity: 87dB/1w/1m
Nominal Impedance: 6.4 Ohms
Dimensions: 520 x 245 x 350mm
Weight: 16Kg per speaker.
Crossover: High quality 12dB/Octave - Point to point wired using the finest components.
Time corrected driver placement.
Recommended amplification: From 35w Valve (PP) or 50W SS recommended.
Cabinet: RFC "Constrained Panel" design using slow grown Latvian Birch Ply
Drivers: Scanspeak Revelator mid woofer: Scanspeak Illuminator Tweeter.
Available finishes:
Oak (pictured);
Walnut;
Red Cherry;
Zebrano;
Curly Maple;
Rosewood.
Sound Quality:
You need to listen for yourself to appreciate just how much scale can be generated from so compact a design. Scale is quite immense. Imaging is expansive thanks to superb off axis performance. It draws you into the music. Detail is fabulous. Tone is natural, unforced and very phase coherent. You can clearly hear the faintest reverb in live studio recordings (pointing to good phase accuracy) and these are very revealing of upstream sources without sounding anything other than natural and involving.
Price: £2,800 per hand crafted pair.
Please contact me to arrange an audition or for further information.
