Page 2 of 144 FirstFirst 12341252102 ... LastLast
Results 11 to 20 of 1437
Thread: Musicraft (Derby) - Clearance + Special Offers
    I'm Rick.
    Clearance/Special Offers - Price update - Yamaha RX-A3030 AV receiver (demo/display unit) in Black finish -
    ***** Musicraft website - Special Offers list http://www.musicraft.co.uk/special-offers/ *****
    Thanks
    Rick @ Musicraft
    Musicraft is Derby's foremost dealer for the finest, specialist Hi-Fi, Home Cinema & Multimedia components/systems. So, if you would like to know more about how our products can enrich your life, then please visit us or contact Rick.
    I'm Rick.
    Clearance/Special Offers list updated to include - Monitor Audio GX300 speakers (demo/display pair - speakers only) -
    ***** Please call before travelling *****
    Thanks
    Rick @ Musicraft
    I'm Rick.
    Monitor Audio GX300 speakers (demo/display pair - speakers only) in Gloss Black finish are provisionally sold
    Thanks
    Rick @ Musicraft
    I'm Rick.
    Chord Electronics Chordette Qute HD DAC (NEW) in Black finish is SOLD
    Thanks
    Rick @ Musicraft
    I'm Rick.
    Monitor Audio GX300 speakers (demo/display pair - speakers only) in Gloss Black are SOLD
    Thanks
    Rick @ Musicraft
    I'm Rick.
    Clearance/Special Offers list updated to include ATC SCM40A Active Monitors + Audiolab 8200DQ DAC/Pre Amp + XLR - XLR Cable 5m/Pair (ALL NEW) Special Package Offer -
    The curved SCM40A is an active version of ATC's highly successful curved SCM40 passive monitors. The 3-way design, employing all hand built ATC drive units is complimented with a built-in 235Watt class AB tri-amplifier. The MOSFET based amplifier is a modified version of that found in ATC's larger active monitors, the SCM50ASL, SCM100ASL and SCM150ASL.
    SH25-76 HF drive unit used in curved SCM40A active monitors
    ATC SM75-150 soft dome mid range drive unit used in SCM40A active monitors
    ATC SB50-164(SC) bass driver used in SCM40A active monitors
    http://atcforums.co.uk/pdf/ATC%20CORP%20BROCHURE.pdf (ATC Corporate brochure)
    Superlative digital media centre featuring 32-bit digital-to-analogue converter/pre-amplifier fully balanced discrete Class-A analogue circuits, a dedicated USB input of asynchronous processing, digital filtering, ample digital and analogue input connections and Class-A headphone amplifier. Comprised of over 1700 components using precision SMT manufacturing on a 4-layer PCB, the Audiolab 8200DQ is the most advanced electronic design in Audiolab’s impressive history.
    Thanks
    Rick @ Musicraft
    I'm Rick.
    Naim UnitiLite All-in-One Player with optional FM/DAB module (demo/display unit) in Black finish is provisionally sold
    Thanks
    Rick @ Musicraft
    I'm Rick.
    Grado SR325Is headphones (demo/display pair) are provisionally sold
    Thanks
    Rick @ Musicraft
    I'm Rick.
    Clearance/Special Offers list updated to include - Monitor Audio GX200 speakers (demo/display pair - speakers only) in Ebony finish -
    Thanks
    Rick @ Musicraft
    I'm Rick.
    Hegel H160 AMP/DAC + Monitor Audio Silver 10 speakers (Black Oak, Natural Oak, Rosenut or Walnut) Special Package Offer (ALL NEW)
    (http://www.hegel.com/images/reviews/H160hifiplusuk.pdf - Hi-Fi Plus Hegel H160 review)
    Hegel H160 AMP/DAC + Monitor Audio Silver 10 speakers (Gloss Black or Gloss White) Special Package Offer (ALL NEW)
    The H160 amplifier has one purpose, and one purpose only - to allow you to connect whatever device you want and make it sound as good as it possibly can. First of all, we designed an integrated amplifier with a broader set of connections than any other amplifier on the market, in this category. There is a wide variety of connections, varying from classic balanced and unbalanced analog connections, to Home Theatre integration and onwards to various digital inputs. You can also stream wireless music to it from devices with Apple AirPlay or DLNA. Secondly, we realized that not all the devices you choose to connect are designed to be high-end music performers. This meant we had to develop a range of unique technologies and implementations to make certain that your phone, tablet or CD-player could reach its fullest potential. The H160 incorporates technology that "repairs" some of the damaged caused by a low quality source.
    Finally, we integrated the new with the classic, and included our award-winning and worldwide patent holding amplifier technology, the SoundEngine. This amplifier design completely turns ordinary amplifier designs upside down. The result is a purer and smoother sound with low distortion, as well as ultra dynamic bass due to a high damping factor. And yes, you can also use your headphones, and it uses up to 60% less power than an ordinary amplifier. So, what are you standing there thinking about?
    Technical Details
    Power output spk: 150 w/pc into 8 Ohms, 250 w/pc into 4 Ohms
    Power output hp: 270 mw/pc into 4 Ohms
    Analog inputs: 1 balanced (XLR), 1 unbalanced (RCA), 1 home theatre
    Analog outputs: 1 fixed line level (RCA), 1 variable line level (RCA)
    Digital inputs: 1 coaxial, 3 optical, 1 USB, 1 ethernet (RJ45)
    Headphone output: 6,3 mm Jack (front)
    Frequency response: 5Hz-100kHz
    Signal-to-noise ratio: More than 100dB
    Crosstalk: Less than -100dB
    Distortion: 0.005% @ 50W 8 Ohms 1kHz
    Intermodulation: Less than 0.01% (19kHz + 20kHz)
    Damping factor: More than 1000 (main power output stage)
    Dimensions/weight: 12cm x 43cm x 41cm (HxWxD)/19kg (shipping)
    Dimensions/weight: 4,7" x 16.93" x 16.15" (HxBxD)/42lbs (shipping)
    http://www.hegel.com/products/integr...60#prettyPhoto
    Hegel SoundEngine Technology
    http://www.hegel.com/technology/soundengine
    http://www.hegel.com/images/reviews/...fichoiceuk.pdf
    Hi-Fi Choice H160 review
    Silver 10 is a completely new model introduction, comprising a three-way configuration in a large floor-standing tower system. Equipped to energise the largest of rooms with naturally explicit wideband audio from music and film sources.
    - Improved C-CAM® (Ceramic-Coated Aluminium/Magnesium) gold dome tweeter design with damped rear chamber and innovative dome venting technique for improved clarity and wider operating bandwidth.
    - Specially developed 4” mid-range driver with ‘under-hung’ voice coil and motor system. The voice coil remains in the magnetic gap ensuring very low distortion - better damping and improved mid-range clarity.
    - Dual 8” bass drivers featuring concave ‘dished’ C-CAM cone profile
    - RST® (Rigid Surface Technology) cone profile, for improved diaphragm rigidity and reduced distortion.
    - Three-way configuration allows drivers to be optimised to deliver better overall performance.
    - Improved cast polymer bass chassis design for better rigidity and reduced reflections.
    - HiVe®II port technology delivers smoother airflow for better transient response and tighter bass.
    - Single bolt through driver systems for increased overall bracing, rigidity and driver/baffle de-coupling.
    - Pureflow® Silver plated OFC copper internal cabling.
    - High quality crossovers with premium grade polypropylene film capacitors.
    - Available in selected premium quality wood veneers or high gloss finishes.
    - Rigid 20mm MDF construction throughout, employing radial and cross-bracing techniques for high rigidity and low cabinet colouration.
    - Invisible magnetic grille fixing provides clean visual styling when the grille is off.
    - Terminal panel at floor level for easy cable connection.
    http://www.monitoraudio.co.uk/products/silver/silver-10
    Thanks
    Rick @ Musicraft
