Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
Thread: Czech Radio upstages BBC
    Default Czech Radio upstages BBC
    I have just written a letter to the London Times -l et's see if it gets printed.
    Our national humiliation is complete. BBC Radio Three used to lead the world in artistic and technical quality, but has been upstaged by Czech Radio. If you have the means to route a high quality audio output from your computer to your HiFi, tune in this Internet Radio Station
    http://radio.cesnet.cz:8000/cro-d-dur.flac
    This world class. The BBC has only very recently made Radio 3 available at 128 Kilobits per second in compressed format that squeezes the life out of the music (WMA); but Czech Radio's Classical Music Station is transmitted at 7-800 Kilobits per second using the lossless free CODEC called FLAC. With a sampling rate of 48 KiloHerz this transmisiion betters a Compact Disc. The stream is also available at a slightly lower quality 224 Kilobits per second using the OGG compressed format - this still beats the BBC's best.
    See the Czech Radio website in English.
    http://www.rozhlas.cz/english/portal/
    The BBC ought to be ashamed of itself.
    Brian
    In Southampton: Raspberry Pi 4 running PiCorePlayer, Beresford Caiman SEG, Quad 77 Int Amp and CD Player, AVI Neutron 4, Sennheiser HD25 headphones.
    In Nicosia: Small Format HTPC, Beresford 7520 ,Quad 405-2, Quart 980s German Tower Loudspeakers.
    Quote Originally Posted by Labarum View Post
    Couldn't agree with you more. The BBC claimed that all their digital broadcasts would be at 256 kbs, however they 'sold out' and now, I believe, the majority are broadcast at something like 98kbs. Radio 3 uses 128kbs and this is increased to 192kbs for the Proms season.
    I'm afraid the BBC stopped leading the world in technical quality many years ago. Basically that's the way Britain has been going (downhill) ever since the '50s.
    im confused... how do i get to listen to this station?
    Quote Originally Posted by hamish_gill View Post
    I normally use a Squeezebox, but it will not receive this Station. The development team is working on it. It's a FLAC in an OGG container, and I don't understand all of that myself.
    I am as I type listening on my laptop which has a Beresford 7520SE (Caiman) connected via USB.
    I have the free player Foobar installed on the laptop - I dropped in the URL - File/Add Location - and off it went. Foobar is running in Vista Exclusive mode (WASAPI) which ensures a bit perfect transfer to the DAC, but that is an extra complication.
    If you have a music player installed on you computer that decodes FLAC, you should be able to tune into the stream.
    Tell what your hardware and software is. I may be able to help - or another member.
    It's worth a listen.
    Brian
    i have worked it out now... that is frankly astonishingly good for radio
    It is. Enjoy it. Let the BBC weep. (But do they care?)
    Brian
    I just realised I could do an A-B test:
    This stream is one of my set Squeezebox favourites
    Title: D-dur Czech OGG 224
    URL: http://www.rozhlas.cz/audio/download/ddur_maxogg.m3u
    And is carrying the same station as the FLAC
    The FLAC is available on the USB input of my Beresford DAC, and the OGG on a COAX S/PDIF
    Button One of the DAC gives me OGG at 224Kb/s and Button Four FLAC at 7-800Kb/s
    The FLAC is clearer, but there is not much in it.
    I rate highly the other East European stations that stream in OGG.
    Brian
    Ashley james was saying similar eighteen months ago and ruined it by saying he liked 128Mb/s MP3's (so so I, but only on simple material).
    Internet radio or streaming music via computer (and small, active, desktop speakers) is where it's going to go and LP (and also CD I suspect) will become even more niche sources.
    I listened some more to the A-B FLAC-OGG comparison. Some Opera came on. I was very obvious when I was listening to FLAC - it was much more "atmospheric" you could hear the ambience of the stage much better, and it handled the dynamics with much more competence.
    I would want to compare some solo piano, a piano concerto and a violin or cello concerto.
    Listening to the FLAC using Foobar I want to compare the three "bitperfect" routines - WASAPI, ASIO and Kernal Streaming - Foobar support all three - a remarkable achievement.
    Brian
    I'm Confused.
    Hi Guys,
    Just a brief note to say that I followed the simple instructions, (thanks Labarum, keep it simple for the likes of me ), and I got the music playing through my system. Whilst the opera type music was not to my taste I could appreciate the quality of the sound - stunning for radio. The more this is put into the public arena the more likely someone at the BBC is to wake up, take their finger out of their arse ( or ears), and do something to get into the game - good luck with the letter to the Times.
    Cheers,
    DaveK.
    My System:
