Hi All,
I'm new to this forum, and joined due to the obvious weath of Technics knowledge available here.
Being a child of the digital generation (despite growing up listening to my parents playing Carpenters LP's and other 60's and 70's records) I have only ever had digital sources. Until recently when a friend lent me one of his Technics SL-1210Mk2 turntables.
I have been blown away by the sound quality, and the organic sound it produces - so I bought the deck off him, and have been contently listening to it for several months. It has been my plan to buy a new deck, such as a Brinkmann Bardo or Oasis, until I discovered all the modifications that can be completed on the Technics (courtesy of this forum), to bring its performance up to a similar or even better level of performance than those TT's.
I have therefore decided to go all out and modify my Technics as far as possible. So far I have decided to go for the following options:
- Mike New Bearing and Plate
- Mike New ETP Platter
- Paul Hynes SR7EHD-21/27 PSU
- Paul Hynes voltage regulator mods and internal silver wiring
- Acoustand plinth with Isonoe feet and shoes
- Output cable rewire
- Removal of pitch control
- Removal/disabling of strobe circuit
- Replacement of LED's (aesthetics only)
- Respray of top cover + general tarting up of all buttons etc (aesthetics only)
- Tonearm - I want to try and keep the original Tonearm, to at least have a few elements faithful to the original design, so I intend to add internal and external damping and rewire either with Cardas or with some bespoke silver/gold cabling.
- Headshell - this will of course depend on the cart, but I will get an upgraded headshell to suit
So, there are a few queries I need some help with:
1. Perhaps most importantly, what cart should I go for? I'm happy to spend up to around £1,500 on a good cart and headshell. I have a preference for a clearly etched and detailed presentation, I don't like a soft, honey coloured presentation that I know many people prefer their analogue to sound. However I want to maximise soundstage size as much as possible.
Carts I have considered so far are:
- Ortofon: SPU Royal GM Mk2' or SPU Silver Meister GM Mk2' or possibly (slightly lower in price) 2M Black
- Audio Technica AT50ANV
- Lyra Kleos
I'd welcome any suggestions in that sort of price range (or indeed performance range - I know price isn't always an indicator!)
2. Regarding the respray I will be having done on the top cover, I want to be able to add the Technics lettering back in afterwards. I have seen that there are stickers and plates available on eBay, but I really wanted the lettering straight onto the paintwork. As I understand it, that leaves silk screening or tampon stamping (stop sniggering!) as available options. Does anyone have any contacts for places that can do this on one off items?
3. Regarding the tonearm. I have read that the stock arm is pretty decent as is, and that adding additional damping and rewire with high quality cabling will take its performance up even higher. That said, will I be holding performance back by going this route, is there really a noticeable difference in replacing such a modified arm with a stock arm from another manufacturer?
4. Finally, have I missed anything obvious on the modding side? Please feel free to offer any other advice or suggestions.
Many thanks in advance.
