Does the problem only manifest itself when one particular source is selected? or at all times?
Shian7
Kudakutemo
kudakutemo
ari mizu-no tsuki
Though it be be broken -
the moon on the water.
- Choshu.
well,most of time CD is the source selected
well,it is not a ground loop,I did the experienece in another room
Prince of Drakness said "Is this perhaps a power supply fault in one of the source components?"
Richard,
Is he right?Please help me asap ,because I have to report this break to Densen service .I want to ship the Densen to Denmark and write a report describing the fault !
Maybe it would be a good idea to try switching on the amp,waiting a few minutes then switching on the C.D. player (or vice versa).
Also, does the hum level vary with volume control setting? If the C.D. player is at fault, I would expect it to.
"Always carry a large flagon of whisky, in case of snake bite and, furthermore, always carry a small snake."
Kevin
Today,I did an experience with another cd player that use RCA´s,unllike my Naim that use DIN and so far the huummm is not so loud,but it still appears for 1 or two minutes but now much more lower!But now it apperas on speakers,not trough the speakers,like some nasty frequence.
What you guy´s suggest?Is it normal,I read on some foruns that many have huummm issues related with amp transformers!
The amp is going back to Denmark!
BTW,is it possible to fix the problem without hearing the nasty noise?
I mean ,it just happens sometimes,I´m affraid that they have to try several times turn on and off the amp until be able to hear it!
If you've given them the symptoms they'll be able to sort it out and will probably have a VERY good idea of what to look at first.
Ben Duncan mains conditioner
Samsung QE75Q90T 75" QLED TV
Atacama SE24 stands
