Page 11 of 26 FirstFirst ... 91011121321 ... LastLast
Results 101 to 110 of 256
Thread: Going Back in Time
  1. #101
    Giffnock? You're joking - I used to live very near there in Crosslees Park!
    Ok, I'll PM you
    P.S From your description, the Marantz sounds like it uses TDA-1541 chips in the DAC - old multi-bit technology, instead of bitstream. I much prefer that.
  2. #102
    I'm Paul.
    Cheers Marco. Replied to your pm.
    The Marantz is a first generation player with the CDM0 mech and twin mono tda 1540 dacs. If memory serves I think it's a 14 bit player.
  3. #103
    I'm Paul.
    Quote Originally Posted by helma View Post
    Nice setup but having the cdp on top of the amp like that seems a bad idea, I think it would work better reversed (the cdp under the amp) or at least elevating the cdp with some feet, hockey pucks or whatever so that there's decent enough room between them to let that amp breathe. Making sure your amp has good ventilation you'll prolong the life of the caps and could even prevent the nasty surprise of something failing.
    You're quite right Kai. The cd player has more clearance than you would think though. The fascia of the Kenwood stands proud of the top of the case by about 5mm and I have already built up the feet on the cd player. However, your point is well made and I will build up the feet another few millimetres. Every little helps. I can't put the cd under the amp as it is much shallower. The amp also has plenty of ventilation from the rear of the top plate where it is not obscured by the cd player.
  4. #104
    Quote Originally Posted by hermit View Post
    Ah, so I wasn't too far off! Still, it'll make CDs sound more like they're supposed to sound, when both the discs and players first came out
  5. #105
    I'm charles.
    hi,deck is looking great,smart move
  6. #106
    I'm Paul.
    A Novus Plastic Polishing Kit arrived today. It's very effective. Here's a couple of before and after shots. Shame about the crack though.
  7. #107
    I'm Paul.
    Default Yamaha C-4 & M-4
    I thought I would try these 1978 Yamahas out whilst my Kenwood 500 amp is at the tech for some fettling. Early days but they might relegate the Kenwood to the subs bench. First impressions are very good.
  8. #108
    I'm Allen.
    I'm gone.
    Wow - I love the look of that tt! - and the Yammie M-4 power amp does look interesting, always fancied trying that or similar.
    Are you able to describe the M-4's sonic presentation compared to other amps you've had?
  10. #110
    I love those Yammie power amps. That was serious kit back in the day. Be interesting to see how it measures up now.
