Grounding the armboard
Hi,
I finally got around to installing my new RB301 on my SL1210. It took longer than I thought it would with all those screws and bolts. Anyway, I was a little disappointed when I fired things up given the level of hum, it wasn't very loud at my normal listening levels, but as I turned up the wick it got pretty bad. I know the RB300 and its successors ground through the left channel, but it seems I am missing something. I played a couple of records, turned off the TT and amp and was off to bed when I thought to myself, perhaps I should check about grounding the arm board.
Simply putting my finger on the armboard and a finger on the chassis of my amp dropped the hum noise considerably. So its obvious to me I need to run a ground wire from that. I also read elsewhere in the forum that grounding the pcb would also help things. I do recall when removing the stock arm it had a ground wire running to either the chassis or the board.
Anyway, so many folks on AOS have put different types of arms on the Techie I was wondering if other people had the same issue and how it was they overcame it.
Nathan
DIY is fine and dandy, but just try selling it on!
Nathan.
