Any recomendtions for USB to SPDIF Converter
I tried this but only lasted a week and merchant will not fix or take back
http://cgi.ebay.co.uk/USB-to-Spdif-T...3A1%7C294%3A50
Which make of DAC are you using John?
Stan
Website: http://www.homehifi.co.uk
Website: http://www.beresford.me
Website: http://www.homehifi.asia
http://www.m-audio.com/products/en_us/Transit.html
is the cheapest from a big maker and has it's own competent Dac as well.
Brian
In Southampton: Raspberry Pi 4 running PiCorePlayer, Beresford Caiman SEG, Quad 77 Int Amp and CD Player, AVI Neutron 4, Sennheiser HD25 headphones.
In Nicosia: Small Format HTPC, Beresford 7520 ,Quad 405-2, Quart 980s German Tower Loudspeakers.
I can not load driver on my laptop (tried site and everything else I can think off) but thanks should of said I tried the M Audio also
What computer are you using? How old is it? What Operating System?
USB implementations are not as standard as they should be, I have read.
The M-Audio should be very reliable - big firm selling lots of kit. Leads me to suspect your computer, if the M-Audo wont work.
Brian
If you are running XP, then have a look at the one that Maplin sells. I think they call it a USB Sound Box. I might have one about. If I still got the driver disc I'll PM you and you can pick it up and try.
Stan
http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=260402381236
Someone on another forum was using one of these.
Naim ND5 XS, nDAC, XP5 XS, 202, HC, NAPSC, 250.2, B&W 804s.
AVR350, B&W HTM4, Gallo.
Samsung, Oppo.
Hi Guys,
Perhaps slightly off main topic but only a little
Can one of my more knowledgeable fellow members advise me on the likely usability of this item for allowing 2 Optical inputs into a StanDAC 7520?
http://cgi.ebay.co.uk/2-Way-Optical-...d=p3286.c0.m14
I have 'invested' my hard earned savings in one and it seems incapable of working as I was assured it should. It quite happily transmits one signal but will not transmit 2 (seperately, not simultaneously ). Am I hoping for too much? Given the extra connections - cable to adapter to cable, rather than cable alone, should I expect a seriously deteriorated signal. Is there any technical reason why it will only allow one input - each seperate input will show a red light at the output port but it is as if one signal is too weak to have any effect when it arrives at the StanDAC.
Any helpful comments would be welcomed.
Cheers,
DaveK.
My System:
Samsung, Oppo.
