Originally Posted by
Stratmangler
Have you actually handled a MNB?
Just to put your comment into context.
I think the answer is probably no, so any comment you make regarding the MNB is pure speculation. Such comments cannot be taken seriously!
The MN spindle feels 'stiff' in comparison with the stock item. This stiffness isn't friction, but drag caused by the very tight tolerance and lubricant. Not a criticism at all sir, so please don't take it as such. The non-quartz Techie direct drives don't have the torque in them and are not over servo'd either. A suitable slightly viscous oil is all that's needed for these earlier bearings IMO.
P.S. Judging from some measurements made by Timestep some time ago, the MN bearing characteristics may well be better suited to the SL1200mk2 electronics, smoothing the very rapid servos out a little better - this latter comment being supposition and gleaned because most if not all who've bought an MN bearing prefer it sonically!
