Hehe, thanks Andrei No Diana Krall, ok
I'll check in later after some more listening...
Turntable 1: Technics SL1210M5G/ KAB PSU/ KAB Fluid Damper
Turntable 2: Rega P3 (new) Tangospinner & dual belt/ Rega Neo
Amplifier: Rega Elex-R
RIAA: Rega Fono mk3 & Schiit Mani
Speaker: Klipsch RP280f
Cartridge: Rega Exact & Nagaoka MP-110
Now the arm cables and phono cable is really opening up. I also changed the loading from 250ohm to 1000ohm on my DL-103R. Wow, it is so airy, tight with a fantastic midrange. I now know what PRaT is! This is in a whole different leage from the KAB arm. That says alot because the KAB arm with Fluid Damper is really good. I also think the TechnyBoots together with Isonoe feet made a difference.
The synergy with all my gear is just as I like it and what I dreamt of when getting back to vinyl last year Tracy Chapman -Crossroads- never sounded so good here
Thank you David and thank you for also sending those plastic spacers in different sizes for the adjustable armboard! Small things, but without those I couldn´t have adjusted the right position for the custom arm collar. That shows me that you prepare everything before you ship! As with the PSU I bought from you last year, all perfect
Next upgrade will be the Isokinetik Silver Melody phono arm cable and Silver Melody RCA from Riaa to tube amp. I really like the sound of the Oyaide arm cable, but the Silver Melody cable might be better? Pm or email me if you like
All in place
Very nice looking Techie- and no doubt sweet sounding record player Chris.
Me so horny- Impulse H6 Horny
Thank you. Armboard is from Mains, that is all I know.
Also this weekend I heard a Rega RP10/ Apheta. Not impressed at all compared to ny modified 1210M5G.
