Results 1 to 10 of 18
Thread: Ebony armboards and SME tonearms?
    Default Ebony armboards and SME tonearms?
    Been speaking to Steve at Magna Audio and my interest was aroused (down boy) about the possibility of a Ebony Armboard for my 1210. I have a Mike New solid Copper version at the moment and it's done it job wonderfully for several years now. I'd just like to put a call out to ALL ebony armboard users and ask for comments, opinions, advice etc. Steve dosen't have a loaner unit so I'd like some help before ordering.
    PRE
    I'm Andy.
    You need wood! l reckon an Ebony armboard would sound better than a metal one- less ringing?
    Me so horny- Impulse H6 Horny
    I'm Andrei.
    I recall our glorious leader Marco also being in a state of arousal at the ebony armboard - some men prefer black I guess. This deviance aside, I might mention my current flavour of the month: Dynamat. This wonder product can be applied to any surface and would tame those micro vibrations. It is almost a free shot - I say almost because it is a right pain to remove if you want to take it off again. You can cut a piece to measure and stick it on the underside of the armboard. Either way it is such a small area I remember being surprised that it seemed to make such a difference. Still it is 'close to the action' ie the tomearm. Or you can go ape and stick dynamat all over every spare surface under the hood.
    [COLOR=#a52a2a][B]Sources:[/B] [B]1[/B][/COLOR] PC & Wyred4Sound DAC-2 DSDse   [COLOR=#a52a2a][B]2[/B][/COLOR] Oppo BDP105   [COLOR=#a52a2a][B]3[/B][/COLOR] Technics SL·1210 MK5 (Jelco 750D · Benz Wood).    [COLOR=#a52a2a][B]Speaker Cable[/B][/COLOR] [COLOR=black]Nordost Frey.[/COLOR]    [COLOR=#a52a2a][B]Interconnects [/B][/COLOR][COLOR=#000000]Oyaide[/COLOR][COLOR=black] & [/COLOR][COLOR=#000000]Geisha [/COLOR][COLOR=black]Silver.
    [/COLOR][B][COLOR=#a52a2a]Phono Stage [/COLOR][/B][COLOR=black]Fosgate Signature V2. [/COLOR]   [COLOR=#a52a2a][B]Preamp [/B][/COLOR][COLOR=#000000]Ayon Eris[/COLOR][COLOR=black]. [/COLOR]   [COLOR=#a52a2a][B]Power Amp[/B][/COLOR] [COLOR=Black]ATC P1. [/COLOR]  ​ [COLOR=#a52a2a][B]Speakers[/B][/COLOR] Triangle Magellan Cello.     [COLOR=#A9A9A9]Oh Sting, where is thy death?[/COLOR]
    I'm Deleted.
    Quote Originally Posted by Tarzan View Post
    Ebony is more like aluminium or a plastic like Delrin than when compared to most other woods. It is exceedingly dense and has an exceedingly tight and fine grain. I've made bits from Ebony and it is far more like turning brass than wood.
    Account Deleted
    what are your thoughts about how it works sonically?
    PRE
    I'm Dimitris.
    In terms of machine work and turning I agree. The grain is very fine and tight. Very nice to work with.
    Ebony though is far more "dead" sonically. It does not ring like aluminum and is perfect for absorbing vibrations, although it is expensive to get it in thick masses.
    Let me rephrase that... it is OMFG EXPENSIVE!!!!!! to get in thick planks...
    My biggest fear is that the ebony armboard is going to completely dull the soundstage. I remember messing around with sorbothane, this stuff completely deflated the drive and slam of my deck. Some people had good results with sorbothane footers, I had a nightmare.
    PRE
    Quote Originally Posted by dimkasta View Post
    Ebony though is far more "dead" sonically. It does not ring like aluminum and is perfect for absorbing vibrations...
    ...which is precisely why it lends itself so well for use as a tonearm board
    My biggest fear is that the ebony armboard is going to completely dull the soundstage...
    Do you honestly think I'd use it if it did? Fear not!
    I'm Robert.
    I'm surprised you'd think that, now a thick piece of sorbothane / rubber I could maybe understand. The ebony armboard is beautiful, sonically excellent and very natural sounding in my experience. Having had one I wouldn't have anything else given the choice. Yep! fear not indeed !
