Page 3 of 11 FirstFirst 12345 ... LastLast
Results 21 to 30 of 109
Thread: Help! I've just bought a Garrard 401!
  1. #21
    I'd clean it and apply fresh oil.
    PRE
  2. #22
    I'm Matt.
    Quote Originally Posted by DarrenHW View Post
    Popped the cover off the motor, some sign of oil in there but not much:
    Does this look okay, can I apply some sewing machine oil and reassemble, do I need to check or clean anything else here?
    To gain access to the felt oil reservoir pads the x4 rivets will need to be drilled out, this will allow you to remove the bearing, spring washer. ball bearing and felt reservoir. Due to Age and heat the felt washer will be varnished as will the pours of the bearings (Hindering correct lubrication feed). If you have no means of re riveting the top and bottom plates the best thing to do will be to clean the bushes as best you can and give them a very good soak. You will note the bearing design is ''self centering' in reality this takes a little time once you re assemble the motor spinning the rotor or pulling gently up and down (Whilst spinning it) to find the sweet spot (Quietest running position), getting this part of the alignment correct once lubricated is the key. The nuts on top of the clams tighten the motor and again have their effect on the alignment so the same procedure again, - sometimes a light knock with a rubber mallet or similar on the corners of the motor assists with gaining the sweet spot (Do not over tighten the motor nuts!)
    Beware the lollipop of mediocrity; lick it once and you'll suck forever.
    www.sellgarrard301.com
  3. #23
    I'm Darren.
    Quote Originally Posted by A.Grail View Post
    To gain access to the felt oil reservoir pads the x4 rivets will need to be drilled out, this will allow you to remove the bearing, spring washer. ball bearing and felt reservoir.)
    Hi Matt, sorry if I'm being stupid but I can't find x4 rivets, when trying to google this I found the following (http://i49.photobucket.com/albums/f2...01-june-17.jpg), amazing restoration btw!
    Darren.
    Listening Room.
    UNDER CONSTRUCTION
    Turn Table. Garrard 401, Reso Mat, 2 Tier Slate Plinth, DIY Hadcock GH242, Nick G modded Lentek, Denon DL-103.
    Pre Amp. Croft Super Micro2. Power Amps Quad 405 Mono Blocks.
    Speakers. TBC
    Home Cinema.
    UNDER CONSTRUCTION
    DAC/Pre Amp. Denon AVC X3700H.
    BDP/Streamer. Panasonic DP-UB820EB / Apple TV4K.
    Display. Optoma UHD51 / DIY False Black Window Screen.
    Power Amps. 2 x Nakamichi AVP1.
    Front Speakers. DIY Baby Celestion Ditton 66. Surround Speakers. Celestion Ditton 11. Subwoofer. BK Electronics P12 300SB PR.
    Old Gallery. http://theartofsound.net/forum/showt...-of-the-70%92s
  4. #24
    I'm Matt.
    My apologies (I blame the Cadmium!) 401's have x3 rivets (301's have 4) See circled in pink
  5. #25
    I'm Darren.
    Cheers Matt, thought I was going mad! I've cleaned the bushing and filled with oil, probably won't have another chance to work on this again till the weekend so I'll leave everything soaking till then. Thanks again.
    Darren.
    Listening Room.
    UNDER CONSTRUCTION
    Speakers. TBC
    Home Cinema.
    UNDER CONSTRUCTION
  6. #26
    I'm Paul.
    Good find. I bought and restored a 401 quite a few years ago and I still have it with no hankering to change it. Mine had a ropey idler wheel which I cleaned with meths and then put into a sealable plastic bag filled with cooking oil and left it to sit on the hot water tank for a couple of weeks. The lighter oils absorb back into the rubber and restore it. 7 - 8 years later the wheel is still in fine condition. A good service really does help with these machines.
    I use a SDS platter on top of the 401 platter and a rubber platter from a Dual 501 on top of that - hey it works for me.
    ~Paul~
  7. #27
    I'm Darren.
    Quote Originally Posted by Primalsea View Post
    Great tip thanks Paul.
    Darren.
    Listening Room.
    UNDER CONSTRUCTION
    Speakers. TBC
    Home Cinema.
    UNDER CONSTRUCTION
  8. #28
    Yo Dazza,
    Love the 401 - nice acquisition... When you get a plinth on it, gizza shout and I'll come and have a listen!
  9. #29
    I'm Darren.
    Yo Dazza,
    Will do, hoping to get it in a plinth with an RB300 this weekend, just so you're prepared it won't be pretty and it may be sat on the floor I'll see if I can move some stuff around but you know what my lounge is like. May have some free time next week, will be in touch when I know what I'm up to .
    Darren.
    Listening Room.
    UNDER CONSTRUCTION
    Speakers. TBC
    Home Cinema.
    UNDER CONSTRUCTION
  10. #30
    Sounds like a plan, muchacho - look forward to it!
    Btw, did you ever get sorted out with some nice ECC82s for the valve output stage on your CDP? If not, I'd recommend these: http://www.tubemonger.com/MAZDA_BELV...MIL_p/1208.htm
    Trust me, they'll be quality....
