Is anyone using the Croft Series 7 mono blocks and are they worth upgrading to from the Stereo series 7 amp or are they only useful in certain applications?
I await this thread with baited breath as I'd like a set!
I'm Richard.
Wrong thread?
ABD.
Tannoyista.com
Why?
I'm Richard.
Hey Joe, Did you have the 7 Mono,s or 7R Mono's?
I don't really need more power but i am thinking of upgrading my Series 7 and was wondering if I would get a more significant improvement in SQ using mono 7's rather than a stereo 7R?
Below...
Not had them but I've heard the 7R mono's.
I've had the 7R stereo amp and that was superb!!! The mono's bring better defined bass, better seperation etc. I really liked them but in the end I missed the sound of BIG output valves so I went with those.
But don't get me wrong, the mono's do have a big sound and plenty of welly but big output valves (when done properly) gives me that little bit more punch. The 7 version of the mono's will still bring better separation and improved SQ I should imagine and everything else but the 'R' version gives the sound a much more refined and controlled signature IMO. - I'm sure others have their experiences in what comes with the R badge but that's what I felt.
I think it's a good move to get your current amp upgraded (with it's extra half) to the mono's - See what you think, then if you decide to go for the R then get those upgraded later.
Can you get to hear some?
Tannoyista.com
Tricky getting to hear some Joe as i think Glenn makes most to order and don,t think there are that many out there. Need to try with my system aswell.
I am with you regarding big valves, they do sound a bit more effortless and open. Pity Glenn does not build his all valve OTL amps anymore they were very good indeed in that respect.dakshini.jpg
That's true, James.
But Glenn will service and update the OTL's accordingly - Might be worth having a look around.
Tannoyista.com
