Page 16 of 20 FirstFirst ... 61415161718 ... LastLast
Results 151 to 160 of 197
Thread: Hegel Audio (+ News & Reviews) - At Musicraft (Derby)
  1. #151
    I'm Rick.
    Musicraft is pleased to announce that on February 8th 2016 we received Hegel Music Systems UK Dealer of The Year 2015 Award which we proudly accepted on behalf of our clients. We and Hegel Music Systems thank our clients for helping establish and achieving great success with Hegel Music Systems in the UK.
    Musicraft is Hegel Music Systems UK Dealer of The Year 2015
    Please contact or visit Musicraft Derby (the UK's leading Hegel Music Systems specialist dealer) to discover why more and more Hi-Fi and home cinema enthusiasts digital and analogue audio systems are benefiting from Hegel Music Systems patented SoundEngine technology.
    Musicraft is pleased to announce that we are the first Hegel Music Systems UK dealer to have received their long awaited ROST (amp/DAC/streamer)
    Picture of the ROST delivery is attached and the UPS tracking information shows us the journey of the new ROST amplifiers from Hegel Music Systems, Oslo (Norway) to Musicraft, Derby (UK)
    ROST (amp/DAC/streamer) the new VOICE of Hegel Music Systems is here at Musicraft (Derby)
    DERBY, GB 25/11/2016 14:18 Delivered
    25/11/2016 5:54 Out for Delivery
    25/11/2016 5:33 Arrival Scan
    Castle Donnington, United Kingdom 25/11/2016 5:17 Departure Scan
    25/11/2016 4:06 Import Scan
    25/11/2016 3:01 Arrival Scan
    25/11/2016 - 02:40 Departure Scan KOELN (COLOGNE) DE
    24/11/2016 - 23:22 Arrival Scan KOELN (COLOGNE) DE
    24/11/2016 - 22:03 Departure Scan MALMO STURUP SE
    24/11/2016 - 21:16 Arrival Scan MALMO STURUP SE
    24/11/2016 - 20:22 Departure Scan GARDERMOEN NO
    Oslo, Norway 24/11/2016 18:20 Export Scan
    24/11/2016 18:20 Origin Scan
    24/11/2016 15:32 Collection Scan
    Norway 24/11/2016 3:45 Order Processed: Ready for UPS
    Röst is the name of one of Norway's most beautiful islands. Way up north in Lofoten. About as far out from the mainland as you can get. The name fits like a glove. Röst can also mean "voice", and the Röst is truly the "voice of Hegel". With the patented SoundEngine amplifier technology, highly advanced preamplifier and delicately designed D/A-converter, the Röst sounds fluidly natural and dynamic. It preserves all the tiny details that create the feeling of being there, and delivers deep, thundering bass when needed. The Röst easily connects to any device you want - a CD-player, a streamer, a computer or perhaps Google Cast Audio? You can connect your iPhone, Macbook or even an AppleTV using AirPlay. Or maybe integrate a Sonos Connect? The choice is yours. Hegel Röst is designed to make everyday devices sound as good as possible, and to make audiophile devices sound even better. We achieve this using proprietary technology developed in-house by Hegel.
    The Absolute Sound - Hegel Music Systems new ROST (amp/DAC/Streamer) is one of the five most significant electronics components at the 2016 Rocky Mountain Audio Fest
    http://www.theabsolutesound.com/arti...le-highlights/
    Hegel Music Systems ROST (amp/DAC/Streamer). Presented by Musicraft (Derby). The UK's leading Hegel Music Systems specialist dealer.
    HEGEL IN A NUTSHELL - Each thing can be found in other amps, but NEVER all three together. This is thanks to our patented SoundEngine technology -
    1. Damping factor - is basically a description for bass control. The higher the damping factor, the better the bass control. Modern amplifiers typically have lower bass control than they used to have 20 years ago. The reason is that the tools you use to increase damping factor will also increase distortion (next - 2). Not so in a Hegel amplifier. Industry average: 60-80, A really good amp: 100-150, 20 years ago: +/-150, Hegel: 1000-4000 Meaning: Hegel can boogie
    2. Distortion - is a description of the level of extra sound that is generated in the amplifier. Meaning sound that is not part of the recording. Distortion usually makes an amplifier sound either muffled or harsh. It will mask the finer details. Modern amps usually have fairly low distortion, and obtain this by sacrificing bass-control (previous - 1). Hegel have among the lowest distortion on the market, and it has it in combination with extremely high bass control. Meaning - it will sound incredibly dynamic, detailed AND smooth.
    3. Power consumption - The third benefit of the Sound Engine technology is low power consumption in idle. We are actually using up to 60% less power. Preventing the amplifier of running too hot, and it is good for the environment. The technical term is low bias.
    The Röst is available in a smooth, white, painted, aluminium and steel chassis. Even the knobs are made of solid aluminium, and have the same comfortable touch. Together with the white, slightly dimmed OLED display, this is a unit you would easily have visible in the home. Ready to be used with your speakers or headphones. The Röst comes with a remote control, made from a solid block of aluminium, but is also IP-controllable and may be integrated in most smart-home solutions. If you have experience in writing code, you can get access to the IP-control table and write your own control systems. Note that we do not offer support on that.
    Hegel Music Systems ROST Technical Details -
    • Power output: 2 x 75 W into 8 Ohms
    • Minimum load: 2 Ohms
    • Analogue inputs: 1 x balanced (XLR), 2 x unbalanced (RCA)
    • Digital inputs: 1 x coaxial S/PDIF, 3 x optical S/PDIF, 1 x USB, 1 x Network
    • Line level output: 1 x unbalanced variable (RCA)
    • Frequency response: 5 Hz - 100 kHz
    • Signal-to-noise ratio: More than 100 dB
    • Crosstalk: Less than -100 dB
    • Distortion: Less than 0.01% @ 50 W 8 Ohms 1kHz
    • Intermodulation: Less than 0.01% (19 kHz + 20 kHz)
    • Damping factor: More than 2000 (main power output stage)
    • Dimensions: 8cm (10cm w/feet) x 43cm x 31cm (HxWxD)
    • Weight: 12kg shipment weightDimensions US: 3.15" (3.93" w/feet) x 16.93" x 12.20" (HxWxD)
    • Weight US: 26.46lbs shipment weight
    Hegel Music Systems ROST RRP £2200
    Hegel Music Systems SoundEngine Technology
    http://www.hegel.com/technology/soundengine
    https://www.facebook.com/hegelmusic/...humbnail_video
    Hegel SoundEngine Technology video with Founder and technical director of Hegel, Bent Holter
    ***** Musicraft - Clearance + Special Offers List http://theartofsound.net/forum/showt...Special-Offers *****
    ***** https://www.facebook.com/MusicraftUK *****
    ***** Musicraft website - Special Offers list http://www.musicraft.co.uk/special-offers/ *****
    Thanks
    Rick @ Musicraft
    Musicraft is Derby's foremost dealer for the finest, specialist Hi-Fi, Home Cinema & Multimedia components/systems. So, if you would like to know more about how our products can enrich your life, then please visit us or contact Rick.
  2. #152
    I'm Rick.
    Musicraft (Derby) is Hegel Music Systems UK Dealer of The Year 2015
    Hi-Fi Plus reviews Hegel Music Systems UK new reference CD Player The Mohican
    http://www.hegel.com/images/reviews/...hifiplusuk.pdf
    Hegel Music Systems new reference CD Player The Mohican in Black finish
    Trivia:
    The name Mohican is inspired by the novel “The last of the Mohicans” by James Fenimore Cooper. Written in 1826, the story takes place in 1757, during the French and Indian War. Now, the scenery inspiring this novel is found by Lake George in Upstate New York.
    Btw, ROST (amp/DAC/streamer) the new VOICE of Hegel Music Systems is in store at Musicraft (Derby)
    Hegel Music Systems The Mohican CD Player. Presented by Musicraft. The UK's leading Hegel Music Systems specialist dealer
    The idea of The Mohican has been with Hegel for quite a few years. Hegel recently found a note from one of their ”product development parties” (yes, you read it correctly) from 2010. It said ”we must make The Mohican. That final CD-Player. The best we can do. Include all those things we have learned since we made the first CD-Player back in 1997”.
    Realism always struck like lightning afterwards, though. We couldn’t possibly devote the team to designing a CD-Player, when they could make AirPlay or whatever new cool thing. Or could we? The Mohican kept being brought up at every meeting, and finally in the fall of 2015 we decided. Let’s do it.
    Let us not care what anyone says, what the excel sheets predicts or what competitors do. Let’s just make the best CD-Player we possibly can, within a realistic price universe. So we did, and here is The Mohican.
    Thousands of people still own thousands of CD's. Some even prefer playing a physical disc, rather than streaming off their phone, when really enjoying their audio system. There is no lack of CD-players, but nowadays most of them are trying to be "everything". They should play SACD, have digital inputs, support DSD and perhaps even have an app and a headphone jack. The problem is that these functionalities not only drive up the cost, but actually reduce the sound quality when playing CD. For years, we wanted to do something about that. And finally it is here... The Mohican - for people who want the best from their CD's.
    The Mohican is something as rare as a dedicated CD-Player. A dedicated CD-Player using the very latest in digital processing - adapted for CD-only. The results are astonishing. Several years ago, when high resolution streaming was in its infancy (but rising), a team from Hegel had a revelation. Listening to a CD-rig, we realized that there was a lot left in CD. Since that moment, there was a never ending debate in the office. Should we go all out, making that final - phenomenal - player? The name was the first thing we decided. It had to be called The Mohican, as in the novel "The Last of the Mohicans".
    This is that super player. The Mohican. It is a true CD-player, using original CD-drive mechanisms from Sanyo, updated with our own designed servo boards. It has the newest and best DAC chips, working in native 16 bit/44.1 kHz resolution. It has the best clock mechanism we have ever designed. We use our patented SoundEngine to control the clock, forcing jitter down to levels we have never reached before. Perhaps the lowest in the world. But let us not bury ourselves in the technical details. What does it do for you? It plays magically natural. It sings... fluid and with great temperament, where needed. Compared to any other digital device we have heard, it simply plays without "edges" in the sound. Almost analogue. Do you dare to listen?
    Hegel Music Systems The Mohican RRP £3900
    The Mohican Technical Details -
    DAC resolution: 16 bit/44.1 kHz
    Line output: 2.6 V RMS
    Analogue outputs: 1 fixed line level (RCA), 1 fixed line level (Balanced XLR)
    Digital outputs: 1 BNC, true 75 Ohm
    Frequency response: 0 Hz - 50 kHz
    Noise Floor: -145 dB
    Distortion: Typical 0.0015%
    Output impedance: 22 ohms unbalanced and 44 ohms balanced
    Dimensions: 8cm (10cm w/feet) x 43cm x 29cm (HxWxD)
    Weight: 6.5kg (net), 9kg (shipping)
    Dimensions US: 3.14" (3.93" w/feet) x 16.93" x 11.42" (HxBxD)
    Weight US: 14.3lbs (net), 20lbs (shipping)
    Thanks
    Rick @ Musicraft
  3. #153
    I'm Rick.
    Hi-Fi Choice reviews Hegel Music Systems new ROST (amp/DAC/streamer) - the new VOICE of Hegel Music Systems
    http://www.hegel.com/images/reviews/...fichoiceuk.pdf
    "It’s easy to see how many prospective customers will delight in plumbing the Röst with a network connection and a couple of other discrete sources to create a modern hi-fi setup that looks very elegant and understated but sounds extremely accomplished. The Röst looks and sounds great and is a joy to use."
    ROST (amp/DAC/streamer) the new VOICE of Hegel Music Systems is at Musicraft (Derby)
    Thanks
    Rick @ Musicraft
  4. #154
    I'm Rick.
    What Hi-Fi India November 2016 issue - Hegel Music Systems H360 (amp/DAC/Streamer) is a do-it-all king amp
    Hegel Music Systems H360 amp/DAC/streamer
    Hegel Music Systems H360. Presented by Musicraft. The UK's leading Hegel Music Systems specialist dealer.
    http://www.theabsolutesound.com/arti...igh-end-audio/
    The Absolute Sound - Hegel's new H360 amp/DAC is one of the thirty greatest bargains in high end audio
    http://www.theabsolutesound.com/arti...ted-amplifier/
    The Absolute Sound reviews Hegel Music Systems H360 amp/DAC/streamer
    "The Hegel H360 is simply a marvelous piece of audio kit. Its neutral tonal balance, articulate and lovely rendering of details, commanding power reserves, spacious soundstaging, and natural imaging are laudable. At $5700, as solely a linestage integrated amp of its quality and power output, it is a bargain; the included nice-sounding and versatile DAC makes it a real winner. I absolutely loved listening to the H360. I never tired of its low noise, dynamic liveliness, and winning musicality. A very easy recommendation."
    http://www.soundstagehifi.com/index....ated-amplifier
    SoundStage Hi-Fi reviews Hegel Music Systems H360 amp/DAC/streamer
    "While some audiophiles may view integrated amplifiers as merely a compromise for those who lack the money or space for separates, this idea is becoming outdated, and there’s no better example of how much things have changed than Hegel’s new H360. It’s packed with features, extremely well built, and has a nice, unassuming design. Most important, its superclean sound and transparency will appeal to those many music lovers who crave detail and resolution. If you’ve got the money, you can’t go wrong with the Hegel Music Systems H360."
    http://www.soundstageglobal.com/inde...the-hegel-h360
    SoundStage Hi-Fi/Global - previews Hegel Music Systems H360 amp/DAC/streamer
    http://www.soundstagehifi.com/index....nic-components
    SoundStage Hi-Fi/Network - Hegel Music Systems H360 amp/DAC/streamer is amongst the five best electronic components of High End 2015
    The Absolute Sound - Hegel Music Systems H360 amp/DAC/streamer is one of the thirty greatest bargains in high end audio
    https://translate.google.co.uk/trans...264&edit-text=
    Stereolife reviews Hegel Music Systems H360 amp/DAC/streamer
    "If you need an amplifier "for life" - if you are tired of being half way there, if you need power to drive your speakers without resorting to monoblocks the size of a subwoofer, or you just want to have a 100 percent high end system in one box. The H360 is a must to listen to."
    Hi-Fi Choice (UK) reviews Hegel Music Systems H360 amp/DAC/streamer
    "Yet, in summary I want to change my sporting analogy. In Hegel combining its extensive know-how around lowering distortion, eradicating noise and preserving phase and transient timing, the H360 is achieving something that is much greater than the sum of the beneficial parts. It’s the effect of watching a truly talented footballer like Messi or Cantona on the ball – time slows down and skill just expresses itself beautifully. Music I know extremely well is refreshed and the artist’s intent becomes clearer. It’s not a matter of extra detail revealed, it’s just effortless, unhampered communication. The sheer cleanliness of the H360’s delivery means I’m better able to understand and enjoy my music"
    “The integrated amplifier is coming of age again, and in the H360 Hegel has created a new reference product in its range that looks to be creating a whole new benchmark performance for others to try their best to match” Chris Ward Hi-Fi Choice (UK) - September 2015
    Hegel Music Systems H360 amp/DAC/streamer with ATC's curved SCM40 passive monitors and two JL audio E-110 subwoofers at Musicraft
    Hegel H360 is a giant among integrated amplifiers. With 250 watts per channel into 8 ohms and a damping factor of more than 4000, it will control virtually any loudspeaker on the market. Thanks to the patented SoundEngine technology, this beast of an amplifier combines power, dynamics, finesse and musicality like no other integrated amp on the market. The connectivity is more of a bonus... There are balanced and unbalanced analog inputs. There is a Home Theatre bypass. There are optical and coaxial digital inputs, as well as a USB input for any signal up to DSD128... And, yes - it is also a streamer. Need we say more?
    The core of everything Hegel is sound quality, and the H360 is no exception. The obvious benefit of the H360 is easy to see - power. It can deliver 2 x 250 watts per channel into 8 Ohms, and is stable even in lower impedances. Furthermore, the damping factor of more than 4000 makes certain it can take control over even the most demanding loudspeakers. The H360 will always play with great authority and ease.
    Rarely is such power combined with finesse. However, specially designed power supplies driving precision volume attenuators contributes to an extremely low noise floor. Hand matching near perfect transistor pairs in the input stage reduces harmonic distortion. Our patented SoundEngine technology reduces over all distortion, and especially cross-over distortion. Our designers understand how transistors work, down to the atomic level, and have used all this knowledge in designing the H360.
    The H360 incorporates a high quality DAC, using Hegel’s proprietary re-clocking. The benefit of this is that we can make everyday sources sound really good. Sources like a phone or a computer. This is why we have also included functionality like Apple AirPlay and DLNA streaming. There is also a reference class USB input, supporting all formats including native DSD64 and DSD128.
    Hegel Music Systems H360 amp/DAC/streamer Technical Details -
    - Power output spk: 250 w/pc into 8 Ohms, 420 w/pc into 4 Ohms
    - Analog inputs: 1 balanced (XLR), 1 unbalanced (RCA), 1 home theatre
    - Analog outputs: 1 fixed line level (RCA), 1 variable line level (RCA)
    - Digital inputs: 1 coaxial, 3 optical, 1 USB, 1 ethernet (RJ45)
    - Digital outputs: 1 coaxial (from digital inputs only)
    - Control input: 3,5 mm IR-Jack (rear)
    - Frequency response: 5Hz-180kHz
    - Signal-to-noise ratio: More than 100dB
    - Crosstalk: Less than -100dB
    - Damping factor: More than 4000 (main power output stage)
    - Dimensions: 12cm (15cm w/feet) x 43cm x 43cm (HxWxD)
    - Weight: 20,5kg (net), 24kg (shipping)
    - Dimensions US: 4.72” (5.9” w/feet) x 16.93” x 16.93” (HxBxD)
    - Weight US: 45,2lbs (net), 53lbs (shipping)
    Hegel Music Systems H360 amp/DAC/streamer RRP £4000
    Thanks
    Rick @ Musicraft
  5. #155
    I'm Rick.
    Hegel Music Systems will be exhibiting at the 2017 CES Show, Las Vegas, Nevada, USA. Venetian Tower - Suite 29-132 (January 5th - 8th)
    More show details to follow.
    Btw, ROST (amp/DAC/streamer/headphone amp) the new VOICE of Hegel Music Systems is at Musicraft (Derby)
    Hi-Fi Choice reviews Hegel Music Systems new ROST (amp/DAC/streamer/headphone amp) - the new VOICE of Hegel Music Systems
    Hegel Music Systems. Presented by Musicraft. The UK's leading Hegel Music Systems specialist dealer.
    Thanks
    Rick @ Musicraft
  6. #156
    I'm Rick.
    Hegel Music Systems are showing/demonstrating their HD30 (DAC/Streamer/Pre Amp) and H360 Amp/DAC/Streamer with a MacBook, Audionirvana, Tidal and KEF Blade 2 loudspeakers at the 2017 CES Show, Las Vegas, Nevada, USA. Venetian Tower - Suite 29-132 (January 5th - 8th)[/b]
    Hegel Music Systems HD30 DAC/Streamer/Pre Amp in Silver finish
    Hegel Music Systems HD30 (DAC/Streamer/Pre Amp) and H360 Amp/DAC/Streamer). Presented by Musicraft. The UK's leading Hegel Music Systems specialist dealer.
    A Meme for Hegel Music Systems HD30 DAC/Streamer/Pre amp
    Enjoy the Music.com Blue Note Equipment Awards 2016 - Hegel Music Systems HD30 DAC/Streamer/Pre Amp
    http://enjoythemusic.com/magazine/eq...l_HD30_DAC.htm
    http://enjoythemusic.com/magazine/eq...DAC_Review.htm
    Enjoy The Music reviews Hegel Music Systems HD30 DAC/Streamer/Pre Amp
    "A truly exceptional DAC!"
    "Bass is wonderfully articulate, even down into the lowest reaches. When the source is up to it, like with "She's Already Made Up Her Mind," from Lyle Lovett's superb Joshua Judges Ruth (Curb), or the 2nd movement of Saint-Saëns 3rd Symphony (Reference Recordings), assuming your other electronics and speakers are up to the challenge of subsonic reproduction, the room pressurizes, with both a clear sense of speed and pitch solidity that is so accurate that you will be startled.I'm simply not used to hearing bass rendered this faithfully, effusively, or completely from a DAC, let alone one in this price range. It plays this portion of the audio spectrum accurately enough that it has the ability to trigger the "Fight or Flight" reptilian response. Because my analog system can create this sensation readily, I know it when I "feel" it. And feel it you do with the HD30!"
    "It delivers an exciting and engaging sense of midrange bloom and body that is more shockingly reminiscent of really great analog than I had expected. This was very welcomed, as it created an incredibly realistic sense of physical size, location, and "space" as good as, or slightly better, than most any DAC I can recall hearing for nearly twice its asking price"
    "This new Hegel further treated me to the most remarkable degree of extension, detail, and resolve in the uppermost octaves. Yet as rife with detail and sparkle as it is, this topmost frequency range is portrayed in an undisputedly relaxed fashion that is extremely captivating, again surprisingly reminiscent of a good analog playback system."
    "But resolve is something at which the HD30 excels, and seemingly so effortlessly; in fact, at levels well above what I would expect in its price class. Honestly, based on its sonic performance alone, I would have put its price at $8000, or even $10,000! It is such an astonishing sonic over-achiever that I don't see this DAC leaving my system any time soon."
    "The new HD30 flagship DAC from Hegel of Norway is one exceptional device. After living with it in place for some extended time, I find myself in full concurrence with Hegel founder Bent Holter's statements as to the significance of this product release in the Hegel constellation of devices. Its combination of exquisitely rendered tone (from subterranean depths to stratospheric reaches), complex and exacting texture, dynamic expressiveness (micro and especially macro!), relaxed, natural yet detailed, vivid, and comprehensive presentation, class-exceeding resolution, and spacious, focused staging and imaging, make it an over-achieving super star. All I can say is that you should not buy a DAC, not even at twice the Hegel HD30's asking price, without auditioning it first! It's your money, and you've been warned!"
    "If you are a die-hard analog hound like me, or have just eschewed using a digital playback system for whatever reason (as I did until about three years ago), this may be the perfect time, and most affordable device, to get you into remarkably satisfying, enjoyable digital playback. The Hegel HD30 has changed how I look at (and listen to) DACs under $8000. I can't imagine you could find anything to quibble with at its price... You will be one satisfied music lover."
    https://www.eisa.eu/awards/hi-fi/15/...017.html#award
    EISA Awards - Hegel Music Systems HD30 DAC/Streamer/Pre Amp is European High-End DAC of the year 2016-2017
    "Built around a very select choice of upsampling and DAC chips, and with some digital wizardry of its own, Hegel’s HD30 is both a DAC/digital preamp and high-end audio streaming solution. This digital control centre offers eight digital inputs, including USB and an Ethernet port that allows the HD30 to function as a DLNA digital media renderer, allowing access to music over a home network, and supporting AirPlay. Moreover it can also drive a power amp directly via its balanced and unbalanced analogue outputs. Full compatibility with high resolution file types, including DSD128, is offered and all are delivered with remarkable impact, sweetness and detail. It’s our first choice for enjoying the highest quality sound without the clutter."
    https://www.youtube.com/watch?v=eC4GUKIPLEM
    YouTube Video - EISA Awards - Hegel Music Systems HD30 DAC/Streamer/Pre Amp is European High-End DAC of the year 2016-2017
    http://www.computeraudiophile.com/co...30-dac-review/
    Computer Audiophile reviews Hegel Music Systems HD30 DAC/Streamer/Pre Amp
    "The Hegel Music Systems HD30 DAC is highly recommended for those who'd like to remove the barriers between good and great sound"
    http://www.soundstagehifi.com/index....alog-converter
    SoundStage Hi-Fi Recommended Reference Component: Hegel Music Systems HD30 DAC/Streamer/Pre Amp
    http://www.soundstagehifi.com/index.php/927
    SoundStage Hi-Fi Products of the Year 2015 - DIGITAL SOURCE is Hegel Music Systems HD30 DAC/Streamer/Pre Amp
    SoundStage Hi-Fi reviews Hegel Music Systems HD30 DAC/Streamer/Pre Amp
    "The HD30’s big selling point is its sound -- and what a sound it is: Its world-class resolution, extreme clarity, and superb refinement let you listen very deeply into recordings, to hear precisely what the musicians and engineers laid down there" "To my ears, the HD30 is one of the best-sounding DACs you can buy today"
    http://www.hegel.com/images/reviews/HD30hifinewsuk.pdf
    Hi-Fi News reviews Hegel Music Systems HD30 DAC/Streamer/Pre Amp
    High Fidelity (Poland) Best Product of 2015 is Hegel Music Systems HD30 DAC/Streamer/Pre Amp
    http://www.stereolifemagazine.com/re...144-hegel-hd30
    Stereolife reviews Hegel Music Systems HD30 DAC/Streamer/Pre Amp
    https://www.youtube.com/watch?v=bPo-zkWpSto
    RAVE Publications at CEDIA 2015 YouTube video showing Hegel Music Systems HD30 DAC/Streamer/Pre Amp
    Rear panel of Hegel HD30 DAC/Sreamer/Pre Amp in Silver finish
    Hegel Music Systems HD30 DAC/Sreamer/Pre Amp RRP £3900
    Hegel Music Systems H360 Amp/DAC/Streamer RRP £4000
    Thanks
    Rick @ Musicraft
  7. #157
    I'm Rick.
    Hi-Fi Knights reviews Hegel Music Systems new ROST (amp/DAC/streamer) - the new VOICE of Hegel Music Systems
    http://hifiknights.com/reviews/aplifiers/hegel-rost-2/
    Thanks
    Rick @ Musicraft
  8. #158
    I'm Rick.
    Stereophile magazine - Hegel Music Systems new ROST (amp/DAC/streamer) - the new VOICE of Hegel Music Systems at the 2017 CES show
    http://www.stereophile.com/content/h...YzcdcwgXX5x.97
    Thanks
    Rick @ Musicraft
  9. #159
    I'm Rick.
    Hi-Fi News reviews Hegel Music Systems UK new reference CD Player The Mohican
    http://www.hegel.com/images/reviews/...hifinewsuk.pdf
    Trivia:
    Thanks
    Rick @ Musicraft
  10. #160
    I'm Rick.
    Hi-Fi Plus magazine (Issue 144 - Alan Sircom)- Hegel Music Systems new ROST (amp/DAC/streamer/headphone amp) - the new VOICE of Hegel Music Systems
    "I confess I was struggling to find a way of describing Hegel’s Röst without using the ‘audio Swiss Army Knife’ phrase already well in circulation. Jet lag helped and I found the answer at about 4am as I jolted awake in a hotel room in Las*Vegas: MacGyver! And I apologise profusely to the people in the adjacent room for shouting ‘MacGyver!’ out loud at 4am (I think they might have thought it was my safe word). But, the Hegel Röst fits that ‘MacGyver’ concept well, although fortunately it’s mercifully free from the late-1980s fashion sense of the original. It really is a ‘do anything’ kind of amplifier that – armed with little more than the tools it comes with out of the box – can work easily with absolutely any music source, and integrates with surprisingly sophisticated home network or home automation systems with equally surprising ease. If you think audio deserves to break free of the Man Cave, or even if you don’t and simply want a damn good amplifier with network benefits, the Hegel Röst is highly recommended."
    Full copy of the Rost review to follow.
    Thanks
    Rick @ Musicraft
