Musicraft is pleased to announce that on February 8th 2016 we received Hegel Music Systems UK Dealer of The Year 2015 Award which we proudly accepted on behalf of our clients. We and Hegel Music Systems thank our clients for helping establish and achieving great success with Hegel Music Systems in the UK.
Musicraft is Hegel Music Systems UK Dealer of The Year 2015
Please contact or visit Musicraft Derby (the UK's leading Hegel Music Systems specialist dealer) to discover why more and more Hi-Fi and home cinema enthusiasts digital and analogue audio systems are benefiting from Hegel Music Systems patented SoundEngine technology.
Musicraft is pleased to announce that we will be the first Hegel Music Systems UK dealer to receive their long awaited ROST (amp/DAC/streamer)
Picture of the UPS delivery label is attached and tracking information shown below as the journey first units of Hegel Music Systems new ROST begins from Norway (Oslo) to the UK (Derby)
25/11/2016 - 02:40 Departure Scan KOELN (COLOGNE) DE
24/11/2016 - 23:22 Arrival Scan KOELN (COLOGNE) DE
24/11/2016 - 22:03 Departure Scan MALMO STURUP SE
24/11/2016 - 21:16 Arrival Scan MALMO STURUP SE
24/11/2016 - 20:22 Departure Scan GARDERMOEN NO
Oslo, Norway 24/11/2016 18:20 Export Scan
24/11/2016 18:20 Origin Scan
24/11/2016 15:32 Collection Scan
Norway 24/11/2016 3:45 Order Processed: Ready for UPS
ROST (amp/DAC/streamer) the new VOICE of Hegel Music Systems is coming soon to Musicraft (Derby)
ROST(amp/DAC/streamer) the new VOICE of Hegel Music Systems is coming soon to Musicraft (Derby)
Röst is the name of one of Norway's most beautiful islands. Way up north in Lofoten. About as far out from the mainland as you can get. The name fits like a glove. Röst can also mean "voice", and the Röst is truly the "voice of Hegel". With the patented SoundEngine amplifier technology, highly advanced preamplifier and delicately designed D/A-converter, the Röst sounds fluidly natural and dynamic. It preserves all the tiny details that create the feeling of being there, and delivers deep, thundering bass when needed. The Röst easily connects to any device you want - a CD-player, a streamer, a computer or perhaps Google Cast Audio? You can connect your iPhone, Macbook or even an AppleTV using AirPlay. Or maybe integrate a Sonos Connect? The choice is yours. Hegel Röst is designed to make everyday devices sound as good as possible, and to make audiophile devices sound even better. We achieve this using proprietary technology developed in-house by Hegel.
The Absolute Sound - Hegel Music Systems new ROST (amp/DAC/Streamer) is one of the five most significant electronics components at the 2016 Rocky Mountain Audio Fest
http://www.theabsolutesound.com/arti...le-highlights/
Hegel Music Systems ROST (amp/DAC/Streamer). Presented by Musicraft (Derby). The UK's leading Hegel Music Systems specialist dealer.
HEGEL IN A NUTSHELL - Each thing can be found in other amps, but NEVER all three together. This is thanks to our patented SoundEngine technology -
1. Damping factor - is basically a description for bass control. The higher the damping factor, the better the bass control. Modern amplifiers typically have lower bass control than they used to have 20 years ago. The reason is that the tools you use to increase damping factor will also increase distortion (next - 2). Not so in a Hegel amplifier. Industry average: 60-80, A really good amp: 100-150, 20 years ago: +/-150, Hegel: 1000-4000 Meaning: Hegel can boogie
2. Distortion - is a description of the level of extra sound that is generated in the amplifier. Meaning sound that is not part of the recording. Distortion usually makes an amplifier sound either muffled or harsh. It will mask the finer details. Modern amps usually have fairly low distortion, and obtain this by sacrificing bass-control (previous - 1). Hegel have among the lowest distortion on the market, and it has it in combination with extremely high bass control. Meaning - it will sound incredibly dynamic, detailed AND smooth.
3. Power consumption - The third benefit of the Sound Engine technology is low power consumption in idle. We are actually using up to 60% less power. Preventing the amplifier of running too hot, and it is good for the environment. The technical term is low bias.
The Röst is available in a smooth, white, painted, aluminium and steel chassis. Even the knobs are made of solid aluminium, and have the same comfortable touch. Together with the white, slightly dimmed OLED display, this is a unit you would easily have visible in the home. Ready to be used with your speakers or headphones. The Röst comes with a remote control, made from a solid block of aluminium, but is also IP-controllable and may be integrated in most smart-home solutions. If you have experience in writing code, you can get access to the IP-control table and write your own control systems. Note that we do not offer support on that.
Hegel Music Systems ROST Technical Details -
• Power output: 2 x 75 W into 8 Ohms
• Minimum load: 2 Ohms
• Analogue inputs: 1 x balanced (XLR), 2 x unbalanced (RCA)
• Digital inputs: 1 x coaxial S/PDIF, 3 x optical S/PDIF, 1 x USB, 1 x Network
• Line level output: 1 x unbalanced variable (RCA)
• Frequency response: 5 Hz - 100 kHz
• Signal-to-noise ratio: More than 100 dB
• Crosstalk: Less than -100 dB
• Distortion: Less than 0.01% @ 50 W 8 Ohms 1kHz
• Intermodulation: Less than 0.01% (19 kHz + 20 kHz)
• Damping factor: More than 2000 (main power output stage)
• Dimensions: 8cm (10cm w/feet) x 43cm x 31cm (HxWxD)
• Weight: 12kg shipment weightDimensions US: 3.15" (3.93" w/feet) x 16.93" x 12.20" (HxWxD)
• Weight US: 26.46lbs shipment weight
Hegel Music Systems ROST RRP £2200
Hegel Music Systems SoundEngine Technology
http://www.hegel.com/technology/soundengine
https://www.facebook.com/hegelmusic/...humbnail_video
Hegel SoundEngine Technology video with Founder and technical director of Hegel, Bent Holter
***** Musicraft - Clearance + Special Offers List http://theartofsound.net/forum/showt...Special-Offers *****
***** https://www.facebook.com/MusicraftUK *****
***** Musicraft website - Special Offers list http://www.musicraft.co.uk/special-offers/ *****
Thanks
Rick @ Musicraft
Musicraft is Derby's foremost dealer for the finest, specialist Hi-Fi, Home Cinema & Multimedia components/systems. So, if you would like to know more about how our products can enrich your life, then please visit us or contact Rick.
