Musicraft is pleased to announce we have received Hegel Music Systems UK Dealer of The Year 2015 Award which we proudly accepted on behalf of our clients. We and Hegel Music Systems thank our clients for helping establish and achieving great success with Hegel Music Systems in the UK.
Musicraft is Hegel Music Systems UK Dealer of The Year 2015
Please contact or visit Musicraft Derby (the UK's leading Hegel Music Systems specialist dealer) to discover why more and more Hi-Fi and home cinema enthusiasts digital and analogue audio systems are benefiting from Hegel Music Systems patented SoundEngine technology.
Presented by Musicraft. The UK's leading Hegel Music Systems specialist dealer.
http://www.soundstagehifi.com/index....ated-amplifier
SoundStage Hi-Fi reviews Hegel's H360 amp/DAC
"While some audiophiles may view integrated amplifiers as merely a compromise for those who lack the money or space for separates, this idea is becoming outdated, and there’s no better example of how much things have changed than Hegel’s new H360. It’s packed with features, extremely well built, and has a nice, unassuming design. Most important, its superclean sound and transparency will appeal to those many music lovers who crave detail and resolution. If you’ve got the money, you can’t go wrong with the Hegel Music Systems H360."
http://www.soundstageglobal.com/inde...the-hegel-h360
SoundStage Hi-Fi/Global - previews Hegel's new H360 amp/DAC
http://www.soundstagehifi.com/index....nic-components
SoundStage Hi-Fi/Network - Hegel's H360 amp/DAC is amongst the five best electronic components of High End 2015
http://www.theabsolutesound.com/arti...igh-end-audio/
The Absolute Sound - Hegel's new H360 amp/DAC is one of the thirty greatest bargains in high end audio
https://translate.google.co.uk/trans...264&edit-text=
Stereolife H360 review
"If you need an amplifier "for life" - if you are tired of being half way there, if you need power to drive your speakers without resorting to monoblocks the size of a subwoofer, or you just want to have a 100 percent high end system in one box. The H360 is a must to listen to."
http://www.hegel.com/images/reviews/...fichoiceuk.pdf
Hi-Fi Choice (UK) H360 review
"Yet, in summary I want to change my sporting analogy. In Hegel combining its extensive know-how around lowering distortion, eradicating noise and preserving phase and transient timing, the H360 is achieving something that is much greater than the sum of the beneficial parts. It’s the effect of watching a truly talented footballer like Messi or Cantona on the ball – time slows down and skill just expresses itself beautifully. Music I know extremely well is refreshed and the artist’s intent becomes clearer. It’s not a matter of extra detail revealed, it’s just effortless, unhampered communication. The sheer cleanliness of the H360’s delivery means I’m better able to understand and enjoy my music"
“The integrated amplifier is coming of age again, and in the H360 Hegel has created a new reference product in its range that looks to be creating a whole new benchmark performance for others to try their best to match” Chris Ward Hi-Fi Choice (UK) - September 2015
HEGEL IN A NUTSHELL - Each thing can be found in other amps, but NEVER all three together. This is thanks to our patented SoundEngine technology -
1. Damping factor - is basically a description for bass control. The higher the damping factor, the better the bass control. Modern amplifiers typically have lower bass control than they used to have 20 years ago. The reason is that the tools you use to increase damping factor will also increase distortion (next - 2). Not so in a Hegel amplifier. Industry average: 60-80, A really good amp: 100-150, 20 years ago: +/-150, Hegel: 1000-4000 Meaning: Hegel can boogie
2. Distortion - is a description of the level of extra sound that is generated in the amplifier. Meaning sound that is not part of the recording. Distortion usually makes an amplifier sound either muffled or harsh. It will mask the finer details. Modern amps usually have fairly low distortion, and obtain this by sacrificing bass-control (previous - 1). Hegel have among the lowest distortion on the market, and it has it in combination with extremely high bass control. Meaning - it will sound incredibly dynamic, detailed AND smooth.
3. Power consumption - The third benefit of the Sound Engine technology is low power consumption in idle. We are actually using up to 60% less power. Preventing the amplifier of running too hot, and it is good for the environment. The technical term is low bias.
H360 amp/DAC with ATC's curved SCM40 passive monitors and two JL audio E-110 subwoofers at Musicraft
H360 amp/DAC
H360 amp/DAC
H360 amp/DAC
H360 amp/DAC
H360 amp/DAC
H360 amp/DAC
H360 amp/DAC
Hegel H360 is a giant among integrated amplifiers. With 250 watts per channel into 8 ohms and a damping factor of more than 4000, it will control virtually any loudspeaker on the market. Thanks to the patented SoundEngine technology, this beast of an amplifier combines power, dynamics, finesse and musicality like no other integrated amp on the market. The connectivity is more of a bonus... There are balanced and unbalanced analog inputs. There is a Home Theatre bypass. There are optical and coaxial digital inputs, as well as a USB input for any signal up to DSD128... And, yes - it is also a streamer. Need we say more?
The core of everything Hegel is sound quality, and the H360 is no exception. The obvious benefit of the H360 is easy to see - power. It can deliver 2 x 250 watts per channel into 8 Ohms, and is stable even in lower impedances. Furthermore, the damping factor of more than 4000 makes certain it can take control over even the most demanding loudspeakers. The H360 will always play with great authority and ease.
Rarely is such power combined with finesse. However, specially designed power supplies driving precision volume attenuators contributes to an extremely low noise floor. Hand matching near perfect transistor pairs in the input stage reduces harmonic distortion. Our patented SoundEngine technology reduces over all distortion, and especially cross-over distortion. Our designers understand how transistors work, down to the atomic level, and have used all this knowledge in designing the H360.
The H360 incorporates a high quality DAC, using Hegel’s proprietary re-clocking. The benefit of this is that we can make everyday sources sound really good. Sources like a phone or a computer. This is why we have also included functionality like Apple AirPlay and DLNA streaming. There is also a reference class USB input, supporting all formats including native DSD64 and DSD128.
Technical Details
- Power output spk: 250 w/pc into 8 Ohms, 420 w/pc into 4 Ohms
- Analog inputs: 1 balanced (XLR), 1 unbalanced (RCA), 1 home theatre
- Analog outputs: 1 fixed line level (RCA), 1 variable line level (RCA)
- Digital inputs: 1 coaxial, 3 optical, 1 USB, 1 ethernet (RJ45)
- Digital outputs: 1 coaxial (from digital inputs only)
- Control input: 3,5 mm IR-Jack (rear)
- Frequency response: 5Hz-180kHz
- Signal-to-noise ratio: More than 100dB
- Crosstalk: Less than -100dB
- Damping factor: More than 4000 (main power output stage)
- Dimensions: 12cm (15cm w/feet) x 43cm x 43cm (HxWxD)
- Weight: 20,5kg (net), 24kg (shipping)
- Dimensions US: 4.72” (5.9” w/feet) x 16.93” x 16.93” (HxBxD)
- Weight US: 45,2lbs (net), 53lbs (shipping)
Hegel SoundEngine Technology
http://www.hegel.com/technology/soundengine
https://www.facebook.com/hegelmusic/...humbnail_video
Hegel SoundEngine Technology video with Founder and technical director of Hegel, Bent Holter
***** Musicraft - Clearance/Special Offers list http://theartofsound.net/forum/showt...Special-Offers *****
***** Musicraft website - Special Offers list http://www.musicraft.co.uk/special-offers/ *****
***** https://www.facebook.com/MusicraftUK *****
Thanks
Rick @ Musicraft
Musicraft is Derby's foremost dealer for the finest, specialist Hi-Fi, Home Cinema & Multimedia components/systems. So, if you would like to know more about how our products can enrich your life, then please visit us or contact Rick.
