Mike
See also this thread http://theartofsound.net/forum/showt...noise-stoppers from a while ago.
fwiw, I bought some RCA and XLR caps from Vintage Audio Lab on the bay but they don't seem to list now. I put them everywhere I could and I reckon it cleaned things up a small but noticeable amount as well as keeping dust out of the sockets. For the low cost, I wouldn't hesitate in buying more.
Chris
Mike
I'm John.
I would have thought those shorting plugs would provide no benefit for your XP-20 pre as it has relayed input which does the same or better job than the shorties?
I'm joe.
I have some cheap ones (not Russ Andrews) in my system. Have to say I didn't really notice any difference sonically but like everyone says they keep out dust at least.
Vinyl: Pro-Ject Xpression MkII + Speedbox MKII + Goldring 1042MM
CD: Cambridge Audio 851C
Network: Bluesound Node 2
Amps: Musical Fidelity A5CR Pre / Power (JS Audio full upgrade)
Speakers: Harbeth Monitor 30.1
Cabling: Tellurium Q Black Diamond / Studio Connections Black Star / Graditech Kide Digital
Mains: James Audio MK7 Power Conditioner, Studio Connections Black Star, Synergistic Research Orange fuses
Support: Creaktiv Rack, Hi-Fi Racks 30.1, Black Ravioli
Mike
Mike
Keith, did you find using a low value shunt resistor was better than a direct short. I can't make out the colours, so what value resistor have you used?
I have seen RCA phono socket "dust caps" advertised for sale on ebay. These simply cover the socket, without shorting out the input. Has anybody tried these and are the results obtained different to that using shorting plugs?
For what it's worth, I believe that unless you live near a high power transmitter or relay mast, or live near an airport with an air traffic control radar, the only benefit in using shorting plugs is to keep dust out and to blank off unused inputs. As others have commented, they are cheap and do no harm.
I recall reading an article a few years ago... May have been on Decibel Dungeon ? Anyway, the author was showing how to put together "shorties" for unused coax outputs on CD/DVD players & these used a 75R resistor.
FWIW I've got some "shorties" here that came with Denon & NAD amplifiers from the factory and they are all the direct short variety.
