Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: Shorties - another cheap upgrade ?
    Default Shorties - another cheap upgrade ?
    The VIDA Phone Pre Amp comes with a couple of RCA plugs for the input not being used
    Which makes me think about Russ Andrews and his 'shorties' - the plugs he suggests we put into Pre Amp inputs not being used.
    Anyone played with these and have some findings ?
    Mike
    I'm Peter.
    Mike
    I've used them and I can't claim that they have made much, if any difference, but they can't do any harm. I suppose they keep the dust out, if nothing else.
    Peter
    Separates Systems:
    (1) Antipodes CX and EX, Matrix Audio X-Saber DSD, Meridian DSP7000 active speakers;
    (2) Lumin D2, Cary CD-308 cdp, Quad 99 power amp, Horns 5degreeN*27 speakers;
    (3) Homebrew PC with Onkyo Wavio SE200 soundcard running Daphile, Quad 44 and 405.2 into Dali Zensor 1s;
    (4) Sooloos C15 plus storage, Braun A2, P1, CD3, C1 and T1 into Sonus Faber Concertos.
    Integrated Home System:
    Sony PS-X600, Naimnet NNT01 DAB Tuner; NS02 Server; NNP01/NNP02 room amplifiers; Netstreams switches, keypads, KEF Ci130QS/Soundlight speakers.
    Not ever seen them mentioned around here so did wonder
    from RA site
    Did you know that the unused interconnect input sockets on your amplifier act can as aerials for interference, polluting the circuit? In our view, the cure is simple!
    Plug our Noise Reducing Shorties into your unused inputs (do not connect them to the outputs). Our tests have shown that you can get a clearer, smoother and more natural sound.
    And here’s a free tip: Unless you are recording, you get a better sound if you have NOTHING connected to the ‘record out’ sockets.
    Mike
    I've got extremely subtle improvements in the past using "shorties" on old amplifiers that have mechanical rotary switches for input selection but on most modern amps with relay switching its pointless as unused inputs are isolated anyway.
    I'm Peter.
    Quote Originally Posted by MikeMusic View Post
    from RA site
    Mike,
    We are in danger of provoking a woo/not woo debate regarding RA if we are not careful!
    They come up for pence on eBay from time to time - can't hurt to try!
    P
    Separates Systems:
    They have been mentioned here a few times - you can buy a whole bag full of them from Taiwan for a couple of quid. I have not found any difference to the sound but they are handy for blocking up unused inputs so you don't plug into them by mistake when swapping cables about around at the back of a rack in poor lighting conditions.
    I'm Neal.
    I've used 'em and like others not found any improvement...they do keep the muck out of unused inputs though!
    I'm Keith.
    I made a load of these a few years ago.
    The difference they make to the sound quality is like night and day*.
    *As observed from the bottom of a very deep cave.
    Keith
    Analogue: Lenco L75 with 'PTP5' top plate in heavy birch ply plinth/re-wired Rega RB300/SAE 1000e HOMC Cartridge/Trans-Fi Reso-Mat/Moth RCM
    Files: Voyage MPD/Custom PC/Supra USB/Beresford ASYNCH-1/Beresford TOSlink cable
    CDP: Inca Katana SE
    DAC: Beresford Caiman MkII (LiPo Battery powered)
    Pre-Amp: Croft Micro 25 Power-Amp: Croft Series 7
    Speakers: DIY Frugel-Horn Mk3 ('FH3') + REL Strata subwoofer
    Headphones: Beyer Dynamics DT990 Pro (250 ohm)/Schiit Asgard Headphone Amp
    Cables - Interconnects: Mark Grant G1000HD Speaker Cables: Van Damme Blue
    Mains: Belkin PF30/Mark Grant DSP2.5 & DSP1.0 Rack: Target
    Office System: HP Win8 Laptop/JRiver/MF V-Link2/Beresford Bushmaster MkII/Topping TP20 Mk2/Mission 771e
    Bedroom System: Raspberry Pi/Raspbrian + MPD/HiFiBerry DAC/Topping TP20 Mk2/Mission 760i or DIY Hybrid Valve-MOSFET Headphone amp + Sennheiser HD595
    Gallery
    I'm Robert.
    'They' know us so called audiophiles will do and try almost anything in pursuit of audio nivana
    FFS.....I'm getting my coat......
    PRE
