I need to get an RCA to 3.5mm looking for the best I can get, looking at Gotham and NVA for RCA to RCA but need the 3.5mm one for my MBP to the hifi.
Belkin do a reasonable one
Bluesound Node 2i
Audio Analogue Pucinni SE
B&W DM607 s2
Klotz ic’s
Not what I'm after, I'm looking for something of equal quality to the kind of normal interconnect I'd use, like SSC or even this Gotham Pro cable for example. Wondering if I could simply buy a interconnect, cut one end off and fit a 3.5mm myself. Not sure how complicated the connection is though.
Wasn't there a Black Rhodium 3.5mm to L/R phono in the MCRU May sale. Would that be suitable if it is still available?
Paul
What's wrong with one of these http://www.ebay.co.uk/itm/1m-iPod-MP...item58853abc85 ?
Chris
Common sense isn't anymore!
That's what I'm after but in the ultra pro version. I'll have to look at the black rhodium one.
