Page 2 of 19 FirstFirst 123412 ... LastLast
Results 11 to 20 of 184
Thread: Van Damme Silver Series Interconnect.
    I'm Craig.
    Thanks for the replies guys, as I mentioned , I already have a pair of their UPVC or whatever the model is ic's, but needed info on the silver series, which so far no one has heard/owned it seems.....
    PS. As a non techie, what do the lo, flat, and hi cap markings refer to, on the link Mark added?
    Bluesound Node 2i
    Audio Analogue Pucinni SE
    B&W DM607 s2
    Klotz ic’s
    I'm Craig.
    Quote Originally Posted by RichB View Post
    My bro in law uses vandamme everything right throughout his studio set up... He's head of audio at a big games company, personally its too flat for my tatses...
    What are tatses?
    A brand of amplifier?
    Bluesound Node 2i
    B&W DM607 s2
    Klotz ic’s
    I'm Craig.
    Quote Originally Posted by Mark Grant View Post
    Is it one of these Craig:
    http://www.vdctrading.com/shop/van-d...de-instrument/
    They should all sound slightly different as they are designed with different capacitance to alter the sound.
    Ah....indeed they are the lo cap ones, so what difference does that make?
    Bluesound Node 2i
    B&W DM607 s2
    Klotz ic’s
    I'm AMusicFanNotAnAudiophile.
    Quote Originally Posted by icehockeyboy View Post
    This is quite salient http://www.aqdi.com/cablecap.htm
    Chris
    Common sense isn't anymore!
    I'm Craig.
    So the lo (west) cap ones are the ones to go for?
    Bluesound Node 2i
    B&W DM607 s2
    Klotz ic’s
    They should affect the signal the least.
    Whether or not you like the sound you get is a different thing altogether
    Chris
    I wonder what the difference is between this stuff: http://www.ebay.co.uk/itm/VAN-DAMME-...item43c29b7f07
    ...and this stuff: http://www.ebay.co.uk/itm/3808973538...%3AMEBIDX%3AIT
    I'm Craig.
    The silver is dearer, so it HAS to be better!
    Bluesound Node 2i
    B&W DM607 s2
    Klotz ic’s
    I'm Paul.
    When I first started building my system I went with this stuff, it's ok for entry level gear but ultimately veiled and a bit nasty in the upper frequencies. Moving to Cardas phono wire was a huge upgrade. I'm now using silver which is a different beast altogether.
    Paul.
    Well apart from the length and the RCA connectors, there doesn't seem to be much difference. But I assume you are referring to the cable itself.
    Suspect there is no difference at all; Van Damme have simply changed the description printed on the cable.
