Tannoyista.com
I'm Paul.
Hi,
2 - 1/2 years later...... I'm thinking of following in your footsteps; I also have a Black Beauty (bb) installed in a Croft preamp. I understand I would gain more transparency, separation and space with a stepped attenuator (SA) instead of the bb. Is the Khozmo still holding up ? Does anyone have a sense of how differently the DACT or even TKD device would present music relative to the Khozmo ? Using a fast and open Decca cartridge on a good tonearm, silver bypasses on the phono stage's Duelund copper caps and fast single driver horns that give air and space aplenty, its hard to imagine just how much more transparency would come through with an SA. Perhaps I'd appreciate the difference on larger scale notionally more congested orchestral material. Concerned that the SA would thin out the sound too much, on the lean tending horns, though they're great now with the BB. Any thoughts much appreciated. Thank you.
I checked out the Khozmo website and that stepped attenuator certainly looks well-made and not terribly expensive. However, can someone explain exactly what a "shunt" attenuator is? I think I already know but I'd like it spelled out for me if possible.
Andrew, a shunt attenuator is one with a fixed series resistor followed by a variable resistance to ground, either by a variable pot, or in the case of a stepped attenuator a selected single resistor to ground.
I use a Khozmo shunt in the prototype of my latest pre design. I've also tried TKD and Tocos pots shunted or otherwise. The Khozmo is the best sounding of all of these and very well made
The very idea of a "shunt" attenuator seems deeply flawed to me. It's a shame the Khozmo doesn't come as a more conventional design because it does look nicely made.
It can sound very good though, and make a cheap pot sound much better too.
Hunter S Thompson
Quite. It's probably not an issue though if using low output impedance sources and has some cost benefits in such cases. The issue with shunt type stepped attenuators is that there's always going to be a conflict between keeping the input to output series resistance as high as possible to maintain a sensible load impedance, especially for higher output impedance sources, with the requirement to pass most if not all of the signal for higher volume settings. Ladder-types or series types would make more sense for valve sources.
You're right though, they do look well made and Arek Kallas, the chap that makes them, is a really nice guy too.
Good article here-
http://www.world-designs.co.uk/forum...ead.php?t=5795
Hunter S Thompson
