Originally Posted by
Mike Reed
GROMIT
Very interesting comparisons, but I'm a little confused.
As you've got a Dorian (and I have a Helikon), I'm not sure why you're trialling these three (I believe, quite dissimilar) units.
The Puresound requires a matching transformer, I believe, before it can be used with a low-output m.c. (and with a healthy 0.5mv output, why bother?)
The Dynavector, I thought, was an active stage in its own right; with p/supply, and no trans. needed.
What is the NVA ? A stand-alone, powered active stage or like the puresound? If the former, how many permutations (if any) does it have for the differing resistance and capacitance values that different cartridges interface with?
Hi Mike - that these phono stages are very different is the very reason why I've been doing a bit of fiddling. The P10 has to use a step-up; the Lyra's output is still way too low to let it work properly, anbd I believe an impedence-matched step-up is the best way of letting it do its best.
The NVA is a fully active stage with a large toroidal psu in a separate box. Works very well in my opinion.
Mike
BTW, I heard a Shostakovich symphony (I think) on Classic FM recently, and noted 'festive' or something similar being mentioned, but can only find reference to a Festive Overture in my Penguin Guide. I don't think I have any Shost., and liked what I heard. Any ideas?
Cheers,
Mike
If it was Classic FM I very much doubt they'd be playing a Shostakovich symphony - faaaaar too adventurous
Seriously, you'll most likely have heard the Festive Overture; a very popular and 'tuneful' bit of Dimitri's finest. 'Feel good' music.
Want to get into some Shostakovich? Try these...
10th Sym - especially the 2nd movement. Terrifying, gripping stuff; possibly my favourite movement of any Shostakovich symphony. Feindish woodwind parts.
5th Sym (perhaps the most popular along with the 7th). Slow movement is especially beautiful - cold, stark, like a Russian winter.
Also try...
24 Preludes and Fugues (piano).
Richard.
Round & round bits: LP12/Cirkus/Kore/Herc II/Roksan Nima/Hana EL
Megabits: Bluesound Node 2i/TEAC UD-H01 dac
Making it louder bits: Phonostage: Dynavector P75 Amp: Cyrus 8vs/PSX-R Speakers: Royd Sintra II
Connecting it together bits i/c's: Flashback Premier. Speaker cables: Van Damme Hifi
