Results 1 to 10 of 14
Thread: Long delay starting up.
    I'm Craig.
    Default Long delay starting up.
    I assumed my Goodmans digi box was on the way out when I was having to wait ages for a picture to come on screen, but having had a shiny new Virgin TiVo installed recently, I'm still getting the same issue.
    It is connected via my Onkyo AV receiver, so the signal goes from the TiVo, into the Onkyo, and then to the screen, I'm assuming maybe the Onkyo is causing it, but why, I have no idea.
    Help anyone?
    Bluesound Node 2i
    Audio Analogue Pucinni SE
    B&W DM607 s2
    Klotz ic’s
    I'm Phil.
    Delve into your on-screen menu's, on our Panasonic there's a power saver setting, which put's it into a deep sleep, when switched on from here it takes quite a while to load everything up, it's confirmed by Pana' to be a slow start up from here as it's acknowledged in the trouble shooting guide. On ours you can set the time of power save mode, so we have it come on at 6am and go off at 10pm. It's just the same on my mother in laws cheap Hitachi box, both are PVR's btw.
    These boxes run on Linux. They need some time to boot up the OS.
    I'm Craig.
    Quote Originally Posted by StanleyB View Post
    So how does that explain that the Goodmans used to be instant?
    Bluesound Node 2i
    B&W DM607 s2
    Klotz ic’s
    I'm Craig.
    Anyone offer another explanation?
    Bluesound Node 2i
    B&W DM607 s2
    Klotz ic’s
    I'm Richard.
    The Onkyo's HDMI handshaking is notoriously flaky. Not sure about the latest models but mine is about 2 years old and sometimes I have to unplug it from the mains because it completely refuses to give me picture from either my Virgin Tivo, PS3, or Raspberry Pi. It's OK as long as you have the TV on and set to the correct AV input, then switch on the receiver, then finally switch on the source, but get the order wrong and it will either A. Take a good 20 seconds to handshake, sometimes more, or B. Not handshake at all, requiring a power cycle of the receiver. Apparently Sky boxes have serious issues with Onkyo amps from around this time.
    It's the one annoyance with an otherwise fine amplifer.
    Rich
    I'm Tim.
    best swap for a yamaha av
    Have you tried a reset of some sort though on the tivo?
    Amp: Rotel A11 Tribute
    Sources:
    Mac mini 2011 and 2014 both ssd’s
    Dac: ifi zen blue
    Leads: tacima’s, Lapp/supra Lorad power leads (home made with mk silver plugs etc), audioquest golden gate rca,
    Speakers: Triangle Borea BR03
    I'm Craig.
    Thanks guys,
    Tim, recently reset the TiVo as it claimed it was overheating, which it wasn't!
    And Richard, I'll try what you suggest, as it is I use a Logitech Harmony that powers up everything at approx the same time. My Onkyo is 4 years old, and has never done this up until about November time.
    I'll experiment and let you know.
    Bluesound Node 2i
    B&W DM607 s2
    Klotz ic’s
    I'm Craig.
    Update time.
    I have tried numerous combinations of what got switched on first, it made no difference.
    But what I did find is that it's the Onkyo that is to blame as it takes an eternity for the Blu Ray playe to start as well.
    Any other suggestions guys and girls?
    Bluesound Node 2i
    B&W DM607 s2
    Klotz ic’s
    I'm AMusicFanNotAnAudiophile.
    Firmware updates all round?
    Gotta be worth a try ...
    Chris
    Common sense isn't anymore!
