Originally Posted by
Alan Sircom
Ignore all the snootiness toward Richer Sounds - Julian Richer's stores are usually very well managed, their prices keen, and their staff well trained, enthusiastic and knowledgable.
I'd have no problem in recommending a system like the one you are proposing. The overall performance should be well balanced, if laid-back in the upper midrange and treble. However, given the trend for excessively thin, bright and forward sounding equipment, this is no bad thing. Bear in mind a lot of how a system sounds falls to the integration between room and loudspeaker, and if the speakers are destined to end up dominating a room 2m x 3m (or disappearing into a room 20m x 30m) you might need to consider smaller (or larger) loudspeakers.
I'd also possibly suggest going for a Pro-Ject Debut Carbon turntable as an alternative to the Rega. It's a little more than the RP1 (£300 instead of £230), but has a better cartridge (Ortofon Red) in situ. While there isn't a lot in it between the two decks, I think the Pro-Ject will be a better match for this system.
Whichever deck you choose though, make sure you place it somewhere level and isolated - a turntable is virtually a backwards seismograph and siting it close to the loudspeakers or on a wobbly floor can play havoc with the performance. It doesn't need to be a dedicated wall shelf designed for the task (although that is ideal), but placing the turntable on top of the amp directly in front of one of the speakers is a definite no-no. Somewhere between the two extremes is best.
Please understand my question mark over Richer Sound was not snootiness. My last experience of a Richer store was exceptionally poor. The salesperson was unable to answer most of my questions and she kept trying to sell me a product I was not interested in, furthermore the store ( I can name and shame if requested) was filthy and everything was covered in dust. The salesman had to blow off the dust when it was picked up.
I know the products are cheap, mainly because they are old stock and the pile it high and sell it cheap is still the business model, but that is no excuse for a dirty store.
Clive
TV LG55B7 OLED
