Page 1 of 9 123 ... LastLast
Results 1 to 10 of 88
Thread: Record Weight on a Techie
    Default Record Weight on a Techie
    What is the consensus of experience here with using a Record Weight or a Record Puck on a Technics TT? I plan to use a weight of <400 grams made of aluminum. I am looking for a weight that does not suck the life out of a record. Does using a record weight take away the life of the record or does it keep it while help mitigating warps? Does the weight and type of material matter when trying to retain the life of a record when using a record weight?
    On one turntable, I have the Mike New AL/CU Copper Platter with Achromat mat using an SME V, and the stock platter with copper mat (my avatar) on another (that one uses the SME 309). Both TTs use the Mike New Bearing and Baseplate.
    CM1
    Anyone who thinks CDs sound better needs to listen to my system. Besides, my cables sound better than yours.
    Technics SL1200-MK2 SE-1: MN Bearing + Baseplate + AL/CU Platter, Paul Hynes SR7 Power Supply, Isonoe Feet, SME V, Audio Technica AT33EV, CableMaker 1 Tonearm Cable
    Technics SL1200-MK2 SE-2: MN Bearing + Baseplate, Copper Mat, Paul Hynes SR7 Power Supply, Isonoe Feet, SME 309, Audio Technica ATOC9/MLII, CableMaker 1 Tonearm Cable
    I'm Confused.
    I seem to recall that Jerry (jandl100) held a mini bake off using different weights on a TT (can't remember which TT) and the heaviest, just short of 800grms IIRC, was deemed to be the best, SQ wise. I use a Mitchell record clamp, much lighter in weight (so very little extra weight on the bearing) but firmly locates the LP on my Techie platter.
    I thought the improvement over and above the use of the 800grm weight was quite noticeable.
    Dave.
    DaveK.
    My System:
    I'm Andrei.
    Quote Originally Posted by DaveK View Post
    I thought the improvement over and above the use of the 800grm weight.
    Dave.
    Very pleased to hear that Dave! I have ordered a Michel that will arrive soon. The reason I have done that is than I consider large weight on the bearing to be a bad thing - though people with heavy weights do not seem to report problems.
    [COLOR=#a52a2a][B]Sources:[/B] [B]1[/B][/COLOR] PC & Wyred4Sound DAC-2 DSDse   [COLOR=#a52a2a][B]2[/B][/COLOR] Oppo BDP105   [COLOR=#a52a2a][B]3[/B][/COLOR] Technics SL·1210 MK5 (Jelco 750D · Benz Wood).    [COLOR=#a52a2a][B]Speaker Cable[/B][/COLOR] [COLOR=black]Nordost Frey.[/COLOR]    [COLOR=#a52a2a][B]Interconnects [/B][/COLOR][COLOR=#000000]Oyaide[/COLOR][COLOR=black] & [/COLOR][COLOR=#000000]Geisha [/COLOR][COLOR=black]Silver.
    [/COLOR][B][COLOR=#a52a2a]Phono Stage [/COLOR][/B][COLOR=black]Fosgate Signature V2. [/COLOR]   [COLOR=#a52a2a][B]Preamp [/B][/COLOR][COLOR=#000000]Ayon Eris[/COLOR][COLOR=black]. [/COLOR]   [COLOR=#a52a2a][B]Power Amp[/B][/COLOR] [COLOR=Black]ATC P1. [/COLOR]  ​ [COLOR=#a52a2a][B]Speakers[/B][/COLOR] Triangle Magellan Cello.     [COLOR=#A9A9A9]Oh Sting, where is thy death?[/COLOR]
    I'm AMusicFanNotAnAudiophile.
    Michel clamp user here too.
    Chris
    Common sense isn't anymore!
    MartinT Guest
    For <400g weight, the aluminium Bruil is a bargain.
    +1. The Bruil weight makes for a rather musically satisfying sound on the Techy. Personally, I don't usually like anything heavier (as it tends to cause a somewhat 'thick' and ponderous sound), although for the short time I heard your Stillpoints, it didn't seem to be doing anything much wrong
    I'm ChrisB.
    ..... a Mitchell....
    ....Michel.....
    ....Michel....
    I don't normally point out spelling errors, but three of you in a row and you're all owners of Michell products too! It's got to be some sort of record.
    Quote Originally Posted by The Grand Wazoo View Post
    I pressed the "L" button twice.
    One of the presses was obviously not sufficient to register
    Chris
    I'm Gone.
    No surely the Michell is the clamp and the record is the thing being clamped
    Did I really make that joke? Sorry.......
    Marco -
    Did you get a chance to compare the Bruil with the Michel Record Weight? If so, what are your thoughts?
    And did you get my PM I sent to you the other day?
