Mindset
You don't expect much from your mum's system and it delivers
I listen to a lower level system when in the kitchen/dining room and it's ok, nothing like my main system and I'm quite happy with it
Some albums are made well and some not so that could be an issue
There's always something to improve. Could be you have one item that needs an update.
Mains is a good place to start - which is where I started when my system sounded poor
Mike
