My sympathy Hal
I'd feel sick too
My sympathy Hal
I'd feel sick too
Mike
Thanks Mike, have been squishing records with better success than I expected. The heat that caused the damage has apparently also helped them recover most of their original shape after being flattened and weights put on. I did that before going to bed, and while it was still quite hot, and it seems that cooling slowly overnight has really helped them recover by over 50%. The three I played today had acceptable warping instead of the stylus bouncing up and down like a yoyo as it did yesterday.
Freely admit to having a near sleepless night after stuffing them up , so it was really great to see improvememt today.
Hal55
Without music, powerboat racing, photography and a whole stack of other stuff that floats my boat, life is just a non stop procession of deadlines and bills.
The vinyl Flat looks a good option.
pressure on its own will not work, it will creep back to the distorted shape.
Vinyl like all thermo plastics has a memory from when it was first formed, if gentle heat is applied it may relax and go back to its original shape. That's what the commercial products are doing, with a bit of presure to help. The two sheets of glass in the sun is also trying to achieve this.
I have noticed on several slightly warped records that have been on my RCM, when I have given them a steam clean using a hand held steam cleaner, that they have initially distorted more then gone back to flat as they cooled. They only get warm with this technique, but you could try any gentle heating method.
Good luck with whatever you try.
Mike
"Health warning as heatwave kills thousands of bats littering the southeast with corpses"
Full story from our Courier Mail newspaper here:
http://www.couriermail.com.au/news/q...-1226795667022
That's sad, the heat was so ferocious there are reports of whole bat colonies dying of heat stress with estimates ranging from the tens of thousands to possibly hundreds of thousands of bats dying in basically a single day. It was shocking conditions for our wildlife.
Hal55
Queensland seems to get the worst of the weather, high humidity, high temps and to top it off floods, down here in Adelaide we get the high temps (over 40C this summer already), but very few floods and humidity can drop to 4% we're lucky but fires are a danger.
Steve.
Kit I have:
CD player, TTs, Phono stages, Pre amps, Power amps, Integrated amps, DACs, Streamers, Speakers and a bunch of cables.
Mike
Biggest problem is the bloody noise from the aircon whilst trying to listen to music
Steve.
Kit I have:
Mike
Reminds me of the six months I spent living in a converted attic over the very hot summer of '97. Even leaving the big skylight open all day I would get back from work to 40 degree temperatures. Solved that problem by listening in my underwear. One advantage was that you could easily get out through the skylight onto the roof parapet which was handy if I wanted to cool off a bit. I don't really feel the heat so living in Oz would not be too much of a problem for me in that respect. The giant spiders are a no-no though
