Page 4 of 7 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 67
Thread: Paradise Phonostage - REVIEW
  1. #31
    Andy, you should probably swap the cartridge loading resistors over to something more suitable for the SPU. Something in the 5-10 ohm range. I've got nothing that low and yours is currently set for 121ohm. It makes a big difference.
    Thanks for the heads up, all this was done on the technics system. So i think you set the paradise up for the cadenza black.
    PRE
  2. #32
    I'm Deleted.
    I doubt it as the recommended load impedance for the Cadenza Black is - >10 Ohm - some distance from 121 Ohm...
    Account Deleted
  3. #33
    Right so I should make a quick call to maplins and get some 5-10oh, resistors, correct?
    PRE
  4. #34
    I'm Simon.
    Maplins, jesus no.
    Get a few of these in 5, 10, 15, 25, 50 ohm http://www.hificollective.co.uk/comp...ors_metal.html and then we you decide which value you like best, replace them with the same value in these http://www.hificollective.co.uk/comp...resistors.html
  5. #35
    Right will get on the blower tomorrow! Thanks for the heads up.
    PRE
  6. #36
    I'm Sam.
    I'm interested in the Paradise Phono stage - on the lookout for people's secondhand ones. Did you ever finish making the comparison?
  7. #37
    Errr...no is the honest answer it's sat in my Valve system and never come out. I have a young daughter now and listening time is limited so the comparison will not happen any time soon.
    PRE
  8. #38
    I'm Sam.
    oh... boo! Maybe just a few words then? You must have listened to it a lot since to get a general idea of what the mono power supply adds to the party. Shame that confusion about the cartridge loading stopped you in your tracks!
    "A good plan violently executed now is better than a perfect plan executed next week - General Patton" comes to mind.
  9. #39
    Quote Originally Posted by Audio Advent View Post
    Sorry! My SPU is now perfectly matched thanks. I may be getting some new monoblocks so things may change again. 8-)
    PRE
  10. #40
    More upgrades on the way
    PRE
