don't confuse him
I'm gordan.
don't confuse him
Gordan.
Speakers: Oris Swing MkII
Amps: Thomas Mayer 300b/ Hiraga La Maison de L'Audiophile 20
Preamp: Silver AVC by eng. Ferenc Lazar
Phono Preamp: Shishido LCR by Solaja Audio
Decks: Garrard 301 Martin Bastin reworked/plinthed with Fidelity Research FR64fx
Garrard 401 in eng Ferenc Lazar solid wenge plinth with SME 3012/2
Cartridges: SPU Spirit/ Koetsu Black revisited by eng. Salai/ Miyajima Shilabe
Step Up Transformers: Tango MCT 999/ Ortofon T-5000/ Lumiere SUT
Digital: Shigaclone by eng. Ferenc Lazar with Lampizator Amber II
Wires: of sufficient length
Just wondering, if you'd plummed for the Kuzma digital psu or if you were just running it into the mains.
I have a Power Inspired Power Regenerator AG 1500 which I bought from Reffc a while ago - it provides a clean 240v ac at all times. Would there be a problem feeding the Kuzma from that rather than buying a new PSU? If it does, it would also give me the means to clean up the supply for my WTT Record Player...
Any thoughts? Am I missing something?
Best
Peter
The Ag1500 will be a good start for a decent 50hz waveform, which is what you need.
You could use any of the following.
Hercules2/Mose low cost, switchable speed psu available as either a pcb only or a fully boxed unit.
Naim Armageddon, a big old transformer in a box which regulates the AC, you'll need to continue using the 45rpm adaptor for this. I still have one of these.
Linn Valhalla, single speed psu. (The Hercules is based on this)
Heed Orbit 1/2
and there's many other diy options available as well as the Kuzma options.
|Both the older Kuzma PSU and the newer digital display unit are both excellent, if somewhat overpriced IMO. But then I build my own.
I'm gordan.
heed owner wouldn't recommend it as his device is prone to overheating when used on stabi s in particular. i know some users who tried it and sold it. i've exchanged a few emails with zsolt huszti about this matter and he won't take any responsibility for heed PSU/stabi S use.
IMHO there is no need experiment here, kuzma PSU is no brainer.
however, it's really not that important to get a supreme performance from this arm/deck combination. i would say it's an icing on the cake but the cake is anyway fantastic.
Gordan.
Jeff and Gordan,
Thanks.
Here goes!
Best
Peter
I'm gordan.
Gordan.
