Another solid ebony armboard for Technics SL-1210 G deck for the lovely Audiomods Series 6 with VTA adjuster.
Bolted in from underneath, flush top surface.
Off to the USA for this one.
Fidelity Research replacement and new parts.
A couple of weights this time.
One a delicate anti-skate weight, the other a super heavy counterweight to balance even the heaviest cart / headshell combos!
Machined from solid stainless steel.
Test fitting on my tonearm
Lateral weight removed
Off to the USA again.
Here's a standalone heavy armpod I made a while back.
Ebony armboard, brass adjustable feet etc
All installed with a Audio Technica 12" arm.
Nice to see things installed.
Resides in the USA this one.
Steve,
Could you produce a 175g version of this. Could you please send me a PM with the pruce please. It's for a SME 3009 S2 improved.
The above 175g is underway.
Materials should arrive today or tomorrow.
Thanks.
Here's the lacquered SME extra screw on weight.
Primer done
Lacquered with Whitworth threaded spigot
Off to Andy in the UK
This arrived today from Steve. I've yet to try it out but it look amazing, so a BIG THANKS steve.
A new 295g heavy counterweight for the mighty Fidelity Research FR64s/FR66s.
Usual delrin insert.
Finished to match the tonearm in stainless steel.
Pictured in my FR64s
I'm working on a EMT 929 mono side weight now, then a FR64s lighter of the two anti skate weight.
Here's the EMT mono cartridge side weight
This and the FR64s counterweight are off to the USA today
