Ok iv'e been offered some platter mats a Herbie's Lab 'Way Excellent',Blue Horizon 2 part cork/composite and a Rubato Copper mat for my techy 1210 which would be best? I havent got a clue or even could this be a 'Poll'?
Rubato Copper mat
Audio Innovations S500 integrated, Art Skibo's, Quad 66 CDP.
I'm Gone.
The two part Blue Horizon is the Garrard mat we developed while I was witj Loricraft Audio. It's part of the energy control strategy I worked on for Garrard and other kit. It's made of a compound originally developed for the CEGB to make mountings for the turbines in nuclear power stations where it's kind of vital to lose vibrational energy beforeit gets back to the reactor. As the turbines got older and more worn this became a problem and they looked for a material that would absorb and damp all frequencies evenly, this stuff was the result.
I think it's a great product and I no longer have any financial axe to grind with it, but would still recommend it whole heartedly. We have them on both techies and Have just got on for the GL78.
Good luck
Once you get into mat swapping you'll never be quite content. They all have subtly different effects on the sound and that varies according to what arm and cartridge you are using at the time. You'll end up chopping and changing forever.
I'm Richard.
There certainly isn't going to be a definitive answer that someone can give you by adjusting a slide rule or checking the alignment of the stars. The only way you'll know for sure is by trying them and listening. A bit it depends on the balance of everything else and what you like. The Achromat, probably the new Marco Delrin wonder mat, and the Blue Horizon from Pauls description of it, are all likely to be attempts at "neutral" - letting you get accurate and revealing if the rest of the kit balances. Others like cork or felt might give you a "flavour" you like, if you are using a system whose limitations mean that the subtleties of the "neutral" mats might just sound dull.
Of course - without a shop that stocks them all, its kinda hard to try them out. There are a few shops you could try. I was really impressed by the Maidstone independant. I would avoid Soundcraft in Ashford. Of course - they won't have a Techie for you to try them on.
If you could describe it - what do you want a mat to do to your sound?
Just want a mat thats not going to add anything or take anything away.
I'm ChrisB.
Why can't you see that there's no sale for you here David?you could put the money towards an ETP platter
Read the thread - Dan has been offered some mats and wants to know which might be the best
Hi Dan
The Oyaide mat + an Oyaide BRone rubber under mat would be worth trying, though the matching record weight is a synergistic match to the mat so ultimately would be required to get the full performance as the designers intended.
Regards Neil
Regards Neil
