Me so horny- Impulse H6 Horny
I'm Tom.
I sent 2 of these interconnects out, one to Frank and another to a local audiophile chap in Shipley, luckily what I heard when I plugged them in is the same as what Frank and Andy heard,
early days yet but the design of the cable has been patented and I had to sign a NDA with the "inventor" of the cable design who lives in Huddersfield and who I met quite by chance.
Yes "inventor" because it is just that, a completely new design that will blow your socks off, any way, enough for now and form an orderly queue please because you will be amazed.
Frank, do you think you could be a touch less enthusiastic in future please? - You've probably priced it way out of my price range and that of one or two others .
Dave.
DaveK.
My System:
Has been granted a patent, or just submitted?
I'm stu.
How much?
301/Puresound 2A3/quite large Grf cab horny ones.Eminence/Coral/Le cleach
I'm Tom.
I can honestly say that no other cable EVER has got me this fired up about it's performance. Yes I have heard a huge number that had some great attributes but all had some form of shortcoming (subtle admittedly), yet I can't find any at all with this cable - it excels in all areas.
I am just as frustrated as you all probably are not knowing even a rough idea of what they are likely to cost
I'm Tom.
It sounds as if it is going to be very expensive. Once talk of a patent breaks cover it is pretty much a given
