I can’t and nor can anyone I know reliably differentiate between 24/96 and 24/192
I can’t and nor can anyone I know reliably differentiate between 24/96 and 16/44.1
I can’t and nor can anyone I know reliably differentiate between CBR320 and 16/44.1
(Two of my friends did have better than chance results depending on the compressor used. Both are recording engineers.)
My niece (18 year old musician) and one of my friends (recording engineer) did do better than chance differentiating between CBR320 and 24/192
The Master recording was made in my friends’ studio and processed through a Metric Halo ULN8.
I can’t hear much beyond 15kHz!
I still prefer to listen to 16/44.1 and above. I may not be able to pick higher sample rates and word lengths in ABX tests but for whatever reason I enjoy listening to these more than I do to CBR320 and below. Make of this what you will.
There are now a decent range of tools to test what you can and can’t hear under various conditions.
http://www.foobar2000.org/components/view/foo_abx
http://sound.westhost.com/abx-tester.htm
http://phintsan.kapsi.fi/abx.html
http://www.libinst.com/Audio%20DiffMaker.htm
http://audio.rightmark.org/index_new.shtml
My personal strategy is too try to investigate original recording wherever possible and listen to those.
I have a large collection of MFSL and DCC recordings now, the majority of which are to my ears more enjoyable to listen to and in general of a high standard.
I’m also rather fond of the repertoire re-masters; Witness by Spooky Tooth for example.
Possibly the easiest method to find recordings that haven’t been mastered to shite is this
http://www.dr.loudness-war.info/
Most of the entries are dated and enough information is given on the individual album pages to work out which issue is likely to have been messed around with least.
I have a few High Res downloads from various sites, some good, some terrible at various resolutions.
I have eventually concluded that bit depth and sample rate don’t make a good recording; what does make a major difference is the engineer that does it.
