Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
Thread: 401
    I'm inthescottishmafia.
    Default 401
    Been servicing my 401 ready for Owston next week, when It'll be played for the first time.
    How quickly should a 401 get up to speed?
    Mine at the mo takes 2 revs for 33 and 4 revs for 45. It's also easy to stop the platter with my finger.
    Is this normal?
    Hunter S Thompson
    Is this normal?
    errr no
    Dominic will be there he will look at your bodge work and fix it ......
    I'm Dominic.
    About half a rev for both 33 and 45 Ali.
    I'm Dominic.
    If I remember Il bring some bits n bobs and get it running better for you.
    Great, many thanks Dom. I have stripped and oiled the motor and it runs freely, as does the idler wheel. Spindle bearing stripped cleaned and oiled also.
    Seems it's slow getting up to speed then. New idler wheel needed?
    Also, how hot should the motor get? Mine gets pretty hot, I can only touch the bottom half of the clam shell for a couple of seconds.
    Hunter S Thompson
    I'm Dominic.
    The motor getting that hot means you need to align the shells a little better and should run cooler. It will get hot but not so you cant touch it for quite a while.
    No need to buy an idler wheel. The replacements available rarely sound as good as the originals. Bit of magic and it will be running much better.
    Ok thanks Dom, I will strip and build up again.
    How come it's so slow getting up to speed then?
    Hunter S Thompson
    I'm Dominic.
    The inner platter face and idler wheel face need dressing. Also use a small mount of grease rather than oil on the idler bushes. Will run quieter.
    Be careful not to over tighten the nuts holding the two halves of the motor together. This may be why your motor is getting a bit hot.
    Ah, thanks Dom, that'll be it, I did them up quite tightly.
    I can't detect any noise at all when it's running though.
    Hunter S Thompson
    BTW, I used a bit of Vaseline on the idler wheel bushes, spins very freely.
    Hunter S Thompson
