Page 256 of 375 FirstFirst ... 156206246254255256257258266306356 ... LastLast
Results 2,551 to 2,560 of 3741
Thread: I Think I'm sure I'm Finished...or Zeppelin to Sinatra & Back
  1. #2551
    got one of these to try today. it will eventually be connected to my stereo so it all comes on and off with a verbal command, but is on test and setup on a light for handiness.
    Once I got the right app it set up fairly easily and seems to work with Alexa voice command or with the iphone app.
    Job done.
    tHIS HAS NOW BEEN INSTALLED INTO STEREO SO i CAN NOW POWER IT UP AND OFF VIA VOICE COMMAND VIA THE ECHO DOT. Very handy when Im struggling. works too
    Very handy.
    Does it go all coy if you talk dirty to it Grant?
  3. #2553
    Very handy.
    She is a lady and i treat her that way
    I'm Paul.
    These connected gizmos are a huge security hole. I'm assuming it works via your main wifi router, if so, you should do some research for how to keep it isolated from everything else as they tend to connect using plain text and basically share your wifi network with anybody nearby.
    SBT/Chromecast/TEAC T1 into TEAC D-T1 DAC or olde-worlde Rega Planar 2 controlled by Rotel RC850 into HH S500D or DACT Passive Pre into Mullard 5-20 monos. Then into Tannoy Cheviots and a Wharfdale sub. All connected by colourful cables.
  5. #2555
    Quote Originally Posted by pgarrish View Post
    As far as i can see they are safe enough i think. No worse than a mobile phone. Probably better
    Default I Think I Am Finished...or Zeppelin to Sinatra & Back
    New jumper leads lol
    ressurected these cables as I forgot to try them due to ill health. found them upstairs and as i was in mood thought I would give them a try with the monos. Took the old cable off and found that the plugs were failing with cracks etc. never really been out much so may have been when I had the accident.
    anyway think there is a distinct improvement
    Will replace all plugs as these were good cables. Sure that will have affected sound somewhat
    These new ones have an increased Capacitance; highs seem a bit more extended.
    I'm Brian.
    You needing any help with these Grant ?
    Regards
    Brian
    Amplifier : Sony TA FB740R
    Speakers : Tannoy 637
  8. #2558
    Hi Brian. Dunno yet mate. Need to see if I have any Shrink left and any better plugs. was thinking of cutting them as these days I really only need a couple of feet each as amps are on speakers
    Hows you doin' anyways. never seen ya for long time, or Gaz.
    I'm sorted.
    I was using that configuration Grant but got this advice elsewhere against putting power amps on speakers -
    'The Tannoys will vibrate (all speakers do) and that will feed back into the electronics (in the amps) which will be microphonic to a degree. This will cause some low level smearing.'
    I'm currently using them on chopping boards on footers on the floor but have to say I've not noticed much (if any) difference.
  10. #2560
    Interesting notion Roy I guess. cant say Ive noticed anything different. worth a thought tho/
