Page 243 of 375 FirstFirst ... 143193233241242243244245253293343 ... LastLast
Results 2,421 to 2,430 of 3741
Thread: I Think I'm sure I'm Finished...or Zeppelin to Sinatra & Back
  1. #2421
    It is a good'un.
    Try it on the solid state output - just a touch more precise and detailed.
    --- and I prefer the volume at the 12 o'clock position!
    well, Ive tried a number of positions and prefer full out and use the vc's on my amps Jerry. much better resolution and soundstage for me. and set it about half way for headphones. Prefer the ss version I think although the valve is ok and interesting too. not done enough testing to come to a conclusion there.
    I'm gone.
    Ah, interesting about the volume control position.
    I probably didn't even try any but the 12 o'clock position on the new one as that was defo preferred on my older version that Martin tried.
    Quite looking forward to getting "your" one back now and having a try with it at full whack!
    -- no rush, really, hang on to it tlll your one arrives, no problem.
  3. #2423
    Been playing vinyl and trying things. Lol
    Ive found puting a slate at front of cd and tt has improved sound. No real idea why but it has
    Vibration reflections maybe
    danilo Guest
    Grab another roof slate and fit it under the TT ?
    See if that makes a difference as well
  5. #2425
    They are tabletop slates.. should have more out in store. Next time i am out i will find them
    I'm gone.
    Nice result, but what on earth made you try it?!
  7. #2427
    I'm Brian.
    He's a slate short of a full dinner set
    Regards
    Brian
    Amplifier : Sony TA FB740R
    Speakers : Tannoy 637
  8. #2428
    lol.
    .. I was getting vibration on cd player and had put a slate between cd and speaker to deflect it which it did a bit but then later wondered if it was getting affected and thus the tt too from the front so stuck a slate in front and boy it sounded better. Must be bouncing of the wall ...there is a mirror there over fireplace. Not easiest place to deaden. Need to think how I can make it more user friendly.
    I'm Timothy.
    Just don't knock that thing off onto your foot Grant! You will be doing the two-step mighty quickly!
    Holbo TT-Nag 110-Croft phono/Innuos Zen MK2/LinnenberG Telemann DAC-Preamp/LinnenberG Allegro monoblocs/Duevel Venus/LinnenberG Maestro SE-Senn. 660S DH Labs cabling
    Croft Series 7 amps, WLM La Scala, Naim Uniti1, Naim Nait XS3, Naim ND5XS2, Guru Junior
  10. #2430
    I'm Russell.
    Quote Originally Posted by nuff View Post
    It sure is! Cheers Grant.
    I am digging the granite topped tables!
